Tall or short Waffle base?
Postby doitright » Fri Mar 28, 2008 9:46 pm
What should I buy the waffle iron with the short base or the tall base. I need to know fast. It is hard to believe but my wife would like a waffle iron to take camping with us. She has a fit if I look at a DO now that we have three of them. Ok ok I have 5 of them she has found all my hidding places :thumbdown: and is looking over my sholder. What I would like to know is what one will cook the best. Also would a 9" or a 8" be better for a family of three.
doitright
REAR DOOR CAMPER
1959 REAR DOOR SCOTTY
doitright
Images: 38
Re: Tall or short Waffle base?
Postby Kevin A » Fri Mar 28, 2008 10:33 pm
doitright wrote:What should I buy the waffle iron with the short base or the tall base. I need to know fast. It is hard to believe but my wife would like a waffle iron to take camping with us. She has a fit if I look at a DO now that we have three of them. Ok ok I have 5 of them she has found all my hidding places :thumbdown: and is looking over my sholder. What I would like to know is what one will cook the best. Also would a 9" or a 8" be better for a family of three.
One of each, you know you're gonna anyway. ;)
#8 is the most common size.
Kevin A
The other guy
Images: 289
Postby bobhenry » Sun Mar 30, 2008 6:21 am
I intend to use mine occasionally over charcoal and could see a definate advantage to the taller base for this type of use. The depth would allow for more coals and a faster cooking time. However if you intend to only use in on a burner the shallow base would put the iron closer to the flame.
Postby doitright » Sun Mar 30, 2008 2:53 pm
That is what I was thinking. If I use charcoal I would need the tall base, and it is also the one to be used on a gas stove. I will go with the tall base and then get the short base when my wife is not looking.
doitright
REAR DOOR CAMPER
doitright
Images: 38
Postby Gaston » Wed Jun 18, 2008 8:33 pm
related question.
How tall is the tall base?? I just acquired a Crescent waffler #8 made by Fanner mfg in Cleavland OH. it is a short base but has tabs that will center it on a section of tube to use as a tall base only I don't know how long to make the "booster" tube cause I don't know how tall the "tall" is . Also has anyone else any information on the "Cresent Waffler"
The difficult we do now... the impossible takes a little longer
Gaston
Images: 98
Return to Cast Iron
