caseydog wrote:I posted this in another thread...
The "8" is the size. An explanation of the other numbers is below.
"As far as collectors are concerned, nothing is special about the letters that sometimes are cast with the pattern number on Griswold pieces and a few other makes. Cast iron pieces are made in a sand MOLD and that mold is made by packing special casting sand around a PATTERN. Each piece of iron has to have its own mold as the mold is a one-time-use thing which is destroyed in order to remove the piece cast in it. In order to make enough molds a foundry might have to have several or more patterns for popular, high production pieces. In this case each pattern has a different letter (plus, usually, one with no letter) on it after the pattern number which would be the same number for like items. It really doesn't make any difference to collectors which pattern was used to make a piece because they were all the same (but sometimes with very minor differences) except for the letter. One of Griswold's most prolific pieces is the No.8 block TM smooth bottom skillet. For these Steve Stephens, a long time collector, has identified all letters of the alphabet (plus no letter), except for the letters I, O, U and Q and some of these could still turn up. Pieces that were produced in low quantities may have only one pattern to make all the molds that were required. The preceeding deals mostly with Griswold pieces but may apply to other makes as well. Wagner called their numbers "catalog numbers" but, basically, they are pretty much the same as Griswold's pattern numbers."
Hey Caseydog, where'd you find that info? Maybe over at WAGS? I'm the one who wrote it and just discovered this site after attending my first (as a visitor) vintage trailer rally yesterday.
Yes, Griswold is great iron cookware and nearly the best you can get. They made so many different pieces and it's all numbered with pattern numbers (except for the very early Griswold prior to about 1892). You just can't even begin to compare what's made new today with old Griswold up to their end of production in Erie, PA at the end of 1957.
Firelion, your Griswold skillet dates from 1940-57 but, if I were to see the underside of the handle, I could get the dates down to within about 5 years of when it was made. Enjoy your pan!
