If you have not used one of these before. Heat the iron up first. You only need to badder one side. If your useing sausage or anyting that does'nt melt then put it in first then pour badder over the top close and flip. If your useing a twix candy bar or other type of chocolite then put badder in first , then the chocolate. Close and flip. Also it helps to use pam spray before you add the good stuff. After about 30 seconds or so you can crack it open and see how brown they are getting
Happy Waffle Dogging.
