Clean Concrete Bonding Agent from Dutch Ovens
Postby 8 » Wed Apr 14, 2021 9:01 pm
So, my wife mentions she noticed a mess in the garage. I bottle of Lanco Concrete Bonding Agent, the white acrylic stuff, got knocked off the shelf when something fell over and the old cap cracked open and dumped almost the entire gallon on a stack of two Lodge dutch ovens, completely filling the lids and overflowing down the sides. By the time I see it, the white liquid on the top lid is already mixing with some color from the seasoning. Even though the lids were on, some leaked inside of them. I took them outside and hosed them off, but some has already started to harden. The stack next to it were in dutch oven bags, so just the outside of the bags got contaminated. Hopefully those will come clean in the wash, but some would not budge with the hose. Luckily only two of the eight ovens got the liquid on them.
Anyway, I have not been on this forum in years, but I figured I would pose the question. How would you clean these ovens to get everything off and make them safe again? My usual method is in the self cleaning oven and then re-season. But I am not sure if I want to do that and have burning acrylic in the house. Maybe I could borrow the neighbors pressure washer first and get off what I can before a self-clean cycle. I also have a jug of phosphoric acid I have used to remove rust, but these have no rust.
Ideas?
It's not fun and games until someone loses an eye.
Visit my blog ... http://www.64ox.com
Re: Clean Concrete Bonding Agent from Dutch Ovens
Postby 8 » Wed Apr 14, 2021 9:14 pm
As for cleaning the Lodge Dutch oven bags, I discovered something. When you run them through the wash, they may be nice and clean when they come out, but the padding in the bottom is now all bunched up in a ball.
Postby John61CT » Thu Apr 15, 2021 7:27 am
Never heard of an oven bag.
Plain cast iron right no ceramics?
Find a solvent for the acrylic, that does not eat away the iron - much, a mm or two is OK
Power drill scrubber is worst case
polish the iron smooth while you're at it
Then season from scratch.
John61CT
Postby 8 » Thu Apr 15, 2021 2:55 pm
https://www.amazon.com/dp/B0008G2W0M/ref=cm_sw_r_cp_apa_glc_fabc_DED124X79B801CXAHAV8
There is a link to a dutch oven tote bag. They are kind of expensive when you consider you could pay more for the bag than you do for some of the Dutch ovens. But I find if I put a small oven in a large oven I can nest two ovens in one bag.
Postby QueticoBill » Thu Apr 15, 2021 4:56 pm
I think I'd try a pressure washer first.
QB
QueticoBill
Images: 22
Return to Cast Iron
