MacTrac wrote:I think most importantly the spring is too stiff. When I said bouncing, I should say, the suspension is too stiff instead.
Still looking no luck...
I doubt there are spring's rated for my purpose. Right/wrong? I was also thinking to drill bunch of holes into them but is that going to help? How hard is it going to be to drill bunch of holes? I think too hard...
What about this product? Is it rated for my purpose? Would it solve the issue?
http://www.northerntool.com/webapp/wcs/ ... _200335740
I think even those might be too stiff; though, you might be able to get a trailer joint to de-rate them (or ones that they carry -- those don't look like they can be opened up to modify) a bit for your application. I think the 425-500 lb torsion axles are for jet skis and what not -- you have even less weight than that! Four bikes are going to weigh no more than 120 lb unless you are a maniac down-hiller. Even if you throw a gear box on there you are up to what, 200? I makes me wonder whether you need to do your own suspension with some motorcycle coil-overs.
Then again, if you put a gear box on there, include the frame in the weight and always carry all the bikes, it might work (but I've seen them down to 425 lb, which I would look for).
I can't remember where I saw the 425 lb torsion axle, a quick look through the data I gathered listed:
Dexter: 600lb
Flexride: 550 lb
Al-Ko: 500 lb
Hopefully someone else will chime in with a lighter torsion axle source.
This guy built one using Northern Tool parts that was pretty light -- you could probably get some ideas from his build although yours will obviously be a bit different:
http://www1.cedar-rapids.net/tdkmotor/s ... ailer.html
