doug hodder wrote:For a thick poofy one like that, your best bet is probably to tie it. I just won't machine quilt worth beans. Get some embroidery floss and a big needle. go through the top and come back up about 1/4" away and then tie it off on top. Cut the thread about 3/4" long after tying it. How far apart you space the ties depends on just how poofy it is. You want to tie it in so that when you wash it, the fill doesn't wad up into a big knot inside. With 2 layers inside, I'd tie it really well. A quilt like that will put a SHAMWOW to shame with the amount of water it can hold. Doug (quilt/fabric store owner)
Just to give a different perspective you can mark out squares and tie the corners I use half of the embroidery floss so the knots are tighter (I'm a wimp) Doug is right about the SHAMWOW effect. You can also tie in lines. Just take your needle and every 2 or 3 inches make a stitch less than a 1/4" but more than 1/8", leave it loose. Then you can cut in the middles and tie it off.
