honeask wrote:Becca, you sure you can't come to the gathering in Louisiana during Halloween, LCG, sort of a "coming home trip" for you? It will be our first gathering with our new teardrop that we will be getting in September. It would be nice to meet you in person.
rebapuck wrote:I haven't been camping since April. I've got a few leaks to take care of before I re-install/re-build the interior of my VW. Then I'm recovering the seat/bed with new different fabric. New curtains and coverlet already bought. However, that is all on hold as it is brutally hot and humid here. I don't do well in the heat.
I did get the quilting bug and have been sitting at my machine for several weeks.
Trying to lose weight too. Not easy since I've been sitting so much. But I am down 9 lbs. Doing low carb at the height of fresh fruit season!!!
S. Heisley wrote:Becca, is it possible that you are getting city water at too high a PSI? You can check that easily. Simply purchase a small, reasonably inexpensive pressure gauge; screw it onto one of your exterior faucets; and turn the faucet on full blast. If the reading is higher than 75, you need a new pressure regulator for your house. That would be a lot simpler and less expensive than all new pipes. Also, check to see if the compression joints were soldered as a lot of times they weren't or were done poorly. If you do get new piping, be certain to get credit for the old pipes' value or sell the old pipes yourself. Copper is now so valuable that thieves are ripping it out of vacant houses and even cutting down electric poles in some areas to harvest it. It could help pay for the re-piping project.
