big brother is watching
Re: big brother is watching
Postby Shadow Catcher » Sun Mar 25, 2012 6:59 pm
There are good reasons for building codes, most of the time. I watch Holms on Homes and you see the the consequences of shoddy construction/remodeling. But then I have known folks that built very interesting homes one out of Adobe another a well known architect artist who used concrete very Goudyesk shells.
I would still like to know the outcome of this.
Postby Engineer Guy » Sun Mar 25, 2012 9:16 pm
I've following this Story somewhat, but I would want to see some 'dry' information on the various Codes, etc., the Authorities are busting this guy on. Knowing both sides of the Story would be necessary to reach a fair conclusion...
I can comment on a few aspects, having built in a Building Code-free CO County. That is, there's no UBC Building Code adoption. So, to build a House required State Permits for Electrical and Plumbing and, especially, a Well. In-House Fresh and Waste Water Plumbing had to be inspected, as did Gas [Propane] Plumbing before the Walls were closed up. The Well had to be permitted in advance before any Driller would even touch the Job. A Permit is required to even sink a hole, even if the Pump is not set. Sometimes, this is done to 'Grandfather' in each State-numbered Well on the prioritized Water Rights System since Water Law changes over time.
County sign-off was req'd - after a Perc Test - on our Septic System and on Propane Tank setting/hookup.
1. Electrical - The local Rural Utility won't even think about hooking up and dropping a Transformer until they see the Permit. So, hooking up and not using the Breakers w/o that Permit is a non-scenario.
Low Voltage off-Grid is possible, but they're also coming under scrutiny. Grid Tie Systems, where Power generated is connected to, and sold back to, the Grid absolutely requires a State Permit. Utility Workers could be electrocuted if such Systems did not disconnect in prescribed ways, and if that work was not Inspected to Code.
2. Concrete Vault Toilets - Forest Service-type Outhouses - are allowed, but also require a Permit.
To the best of my knowledge, a Composting or Incinerating Toilet can be installed w/o Permitting.
3. We are ~3/4 Mile from the closest District Water System, so that run of Pipe - and monthly Water Bills forever - were less attractive than a Well. Connecting to this Water System required a 'very typical' Tap Fee or ~$13,000 or so, and that Fee goes up over time.
The first step in building was to get an Address for our raw Land. This ensures a new Driveway is not put at the crest of a dangerous Hill, etc.. However, in a cascading scenario, Permits cannot be pulled and Subs like Well Drillers won't show up without an 'official' Address.
Comparing Notes with Pals who've built elsewhere, I believe these CO Building legalities are pretty typical and fairly low key.
The kicker in this Story would be to know how 'reasonable' [or not] Local Authorities are being, and which issues are at stake. Water, Poop, and Electrical shortcuts can be serious, and could be inherited unknowingly by the next Property Owner.
Engineer Guy
Images: 118
