Tank appeared clean, but it won't run...
Postby doug hodder » Sun Jun 27, 2010 11:42 pm
One of the awards for the IRG appeared to have a nice clean tank when I shined a flashlight into the tank...but once fueled...it ran crappy! It would kinda run, then flood and get a nice yellow sooty flame, then kick back to normal.
I dumped the fuel through a paint strainer and this is what I found. Not rust, but it appears to be a varnish from old fuel in the tank that lifted once new fuel got into the tank. I guess the lesson here is don't be fooled about the interior of the tank till it's completely cleaned. Tore it apart again, cleaned out the innards, and it runs great now...and to think that the bottom of the tank looked so nice and shiny.
I could be wrong about what it is exactly, but it's not metallic, based on the magnet. Who knows what someone put through it for fuel though. Word to the wise...clean your tanks! Doug
Postby Ratkity » Mon Jun 28, 2010 7:04 am
That looked like blood at first! LOL.
Glad you got it running!
Hugs,
Ratkity
Ratkity
Postby starleen2 » Mon Jun 28, 2010 7:21 am
been "caught" like that before! Now I break out the BB's for a quick shake in the fount, rinse, repeat, rinse, repeat - done
starleen2
5th Teardrop Club
Postby Dean in Eureka, CA » Mon Jun 28, 2010 8:26 am
Wow Doug,
You sure have put in a lot of work and effort... You Da Man!!! :applause:
I've just about got the globes ready to do a light dusting... Two more to cut the resist out on.
My eyes sure aren't what they use to be, or I need stronger glasses...
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby WarPony » Mon Jun 28, 2010 12:08 pm
starleen2 wrote:been "caught" like that before! Now I break out the BB's for a quick shake in the fount, rinse, repeat, rinse, repeat - done
Yip, what preacher man said :thumbsup:
Jeff
WarPony
Images: 289
Postby Steve_Cox » Mon Jun 28, 2010 3:04 pm
It is "varnish" someone probably let the tank evaporate dry at some time. I get that stuff all the time on boat gas tanks. I liked the BB method of cleaning, ingenious :thumbsup:
Steve_Cox
Images: 196
Postby G-force » Tue Jun 29, 2010 2:47 am
Be carefull putting bb's or other things in a tank. A handfull of nuts and bolts has been a standard for cleaning the inside of motorycycle gas tanks for yeas. Works good untill I tried to get them out! The fill neck had a flange around it so you could not dump them out and the were too big to go through the petcock valve hole! Ended up picking the out, one by one with those springloaded mechanics "fingers." So, the solution is a short length of small chain, keep one end out and bingo, its easy to pull out. However, be carefull, I tried this trick with an old Coleman gas lantern and the chain got hung up on the pressure pump tube on the inside!
Mike
G-force
Images: 22
Postby teardrop_focus » Tue Jun 29, 2010 12:15 pm
If whatever media you're using to help scour the inside of a fount or a tank is ferrous and becomes trapped by a filler cap neck flange or whatever, you can always use the magnet-on-a-stick media removal program.
:pipe:
That last BB is always a challenge to shake out. As much so as trying to shake a pic out of a guitar (which seems easier).
:lol:
teardrop_focus
Images: 127
Postby hotrod » Tue Jun 29, 2010 6:50 pm
teardrop_focus wrote:If whatever media you're using to help scour the inside of a fount or a tank is ferrous and becomes trapped by a filler cap neck flange or whatever, you can always use the magnet-on-a-stick media removal program.
:pipe:
:lol:
Im glad my bow doesnt fit inside my fiddle....lolololol
Paul
hotrod
TILT
TILT
