slowcowboy wrote:I have bought a check valve removal tool on ebay and have troubles with the check valve on my 228E I have tried to remove the check valves on 2 parts fonts that are not being used.
I have had no sussese and have ended up in just stripping the slots in the check valves. they are rusted in good.
anyone acutally get a check valve out with out giving up and just swaping fonts?
slow
Done it several times - And without the tool! - I have A big slotted screwdriver that I ground the end down to match the slot. Sometimes the valve is stuck in there because of age, varnish, and sealer. Sometimes a few good raps on the valve will get it loose from the threads - a few good blows from a hammer on the end of the screwdriver does it for me ( but not gorilla blows - nor gentle taps = something in between). I've also used a gentle warming with a torch to help it out as well. Be care though with this method - the bottom of the cylinder is soldered on! - sure would hate to have it v fall of due to excessive heat.
This brings me to a very good point - if the check valve is OK - then don't mess with it! - same thing goes for valve needle and tip clear graphite packing - if it is doing a it's job - then leave it alone.
