Coleman Keepers Campfire come on in!
Re: Coleman Keepers Campfire come on in!
Postby Wolffarmer » Sun May 20, 2012 12:30 pm
logman7777 wrote:Im not giving in..I have plenty of Colemans (12 at last count) Must...Not...Give..In... :?
Wolffarmer whispers, "Come to the light, follow the light"
Randy
Wolffarmer
Images: 309
Postby campmaster-k » Sun May 20, 2012 12:39 pm
I was not going to go, we have a bunch of family in town. I had to cook and entertain and all that. I did sneak off to the bootfair this morning - just for an hour or so.
It was glorious. This is what I took home.
The first is a 220D 1947. $12
Next is my FIRST maroon 200A. My heart started racing when I saw it. $10
The vent is almost perfect. It will be a great rebuild.
Next is a 1966 200A broken glass but decent. $8
And a 425E that I dont need or want, I just could not stop myself.
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Postby Wolffarmer » Sun May 20, 2012 1:31 pm
campmaster-k wrote:I was not going to go, we have a bunch of family in town. I had to cook and entertain and all that. I did sneak off to the bootfair this morning - just for an hour or so.
[/img]
I thought we was your family now.
Nice haul. I really like that 220D
I took my rich running Mil Spec out to the wood shed ( shop ) and tore the burner cage off and found in that 1967 Coleman both of the air tubes are used, unlike the 2 SMPs I had looked at yesterday. But I could see remains of a mud dabber in there.Reamed them out and blew them out. Tied on a new mantel while the cage was on the bench and reassembled. Fire that baby up and now it is burning nice a sweet. Noisy of course. Yesterday when I started to put mantles on I opened up a 6 pack of what looked to me some no name or who knows what mantles. But they turned out to have Thermos on them. Could not see the thermos through the package. Wow those sure do burn pretty and white.
But it sure is strange that Coleman started to burn rich when it did after several fonts of fuel. only thing I can think is something broke loose and lodged in there just right. None of the burner tubes was plugged by any more than a bit of mud on the walls.
Randy
Wolffarmer
Images: 309
Postby Wolffarmer » Sun May 20, 2012 1:39 pm
bonnie wrote:While out thrifting with my daughter I found a Coleman 425B. $7. Everything seems to be there, including fuel in the tank. :shock: I will probably set it aside for the moment and get the garage cleaned up, before I start making stove parts everywhere. It needs cleaned. All the old stickers are on it, so I probably won't paint it. I couldn't find a date, but did see a sticker that instructed how to lower the legs that has the following on it: 1950-624. If that's the manufacture date, this thing is older than I am. :lol: :lol: No pics tonight. Maybe when I cook on it the first time. :)
Bonnie
I like those old 425s The oldest I have is a 425C, maybe 2 I forgot. I think yours has the "Pipe" shaped fuel tank. If I could find one of those in good usable shape I would put it in the TD instead of the 425F I have had since 1988. And used a lot.
A whole lot.
Randy
Wolffarmer
Images: 309
Postby Wolffarmer » Sun May 20, 2012 8:57 pm
Here is a little something I picked up a month or so back from ShopGoodwill.com. At least it wasn't the bay.
I haven't done anything with it yet. Does make a fine paper weight.
Randy
Wolffarmer
Images: 309
Postby nevadatear » Sun May 20, 2012 9:01 pm
220 box it is. Ceramic burner caps and steel directions disc(how obvious that is now that I know )
nevadatear
Images: 171
Postby nevadatear » Sun May 20, 2012 9:13 pm
Make that. Bx auto spell check on the iPad. Whoops. Randy just tried to light it. Holds pressure. The bent over doohickey that adjusts the flame is "frozen" says my hubby. He's a working on it.
nevadatear
Images: 171
Postby Zollinger » Sun May 20, 2012 9:14 pm
Hey look the first thing that you can iron is the cloth the iron is on! :R
Dawn
Green Lantern Corpswoman
Zollinger
Images: 64
Postby Kevin A » Sun May 20, 2012 9:34 pm
nevadatear wrote:Make that. Bx auto spell check on the iPad. Whoops. Randy just tried to light it. Holds pressure. The bent over doohickey that adjusts the flame is "frozen" says my hubby. He's a working on it.
The "doohickey" doesn't adjust the flame, it cleans the tip on the generator. Under burning conditions it should be in the down position, if you need to clean the tip you'll want to rotate it a complete turn or two to clean the carbon from the genertor tip with it returning to the down position. :thumbsup:
Kevin A
The other guy
Images: 289
Postby Wolffarmer » Sun May 20, 2012 9:40 pm
Zollinger wrote:Hey look the first thing that you can iron is the cloth the iron is on! :R
ME!!!! IRON??????, those words do not go together.
Randy
Wolffarmer
Images: 309
Postby nevadatear » Sun May 20, 2012 10:21 pm
Thanks Kevin. He did figure out the part about it being the tip cleaner from the parts diagram. I still am not sure about the single mantle. It is stamped with 3. And then 4 and a nickel fount. 242 but what version.? I am confused by the dating scheme change is it march of 44 or April of 43. Oh and the220bx lit right up! Needs a tune up though. Randy is intrigued and gonna get them going I think. I see by the lack of eBay postings the Bx seems to be not so common.
Hum there is a leak on the Bx at the tip cleaner.
nevadatear
Images: 171
Postby nevadatear » Sun May 20, 2012 11:14 pm
nevadatear wrote:We had something unusual in our little burg last weekend, an small estate auction. Randy and I went out and couldn't resist. Now, we are not becoming collectors, it was just too good to pass up. Four lanterns and a vintage first aid kit for the nurse for $25. Here is what we got before I washed them up a little.
After clean up
One at a time. We're going to keep this single mantle. It matches the trailer. It needs a screw (not a nut) on the top to hold the top in place. Anyone? I lost my paper that I had the model and age. I think this one is 1948
This one is says 3 3 on the bottom and is in great shape
This big hat is 1947. The fount is in pretty bad shape and has no globe. Maybe useful for parts.
This one is also in great shape, but it is 1974
We figure we will keep the single mantle 242, give away one at IRG raffle, maybe offer one to a real collector for the price of a tune up on the one we want to keep. Any takers? Did we do good?
first aid kit from the mid 40;s
I found my notes and with you all's help I think I have them dated and id'ed
The single mantle with the nickel fount is 242c march of 1944
The all green with the yellow label is a 220bx march of 1943-/
The nickel font/green big hat is 228d April 1947
The baby of the group is the all green 220j. 1978
Thanks everyone. Now randy just has to get three of them running fir the IRG.
nevadatear
Images: 171
Postby Darren » Mon May 21, 2012 8:15 am
If you decide to get rid of the BX let me know. I sold the only one I had to a collector, it was his Birthday lantern so I had to. :thumbsup:
Darren
the camper formerly known as Victor Star
Images: 161
Postby Scouterjan » Wed May 23, 2012 12:11 am
Nevadatear, your single mantle looks like a 242, no letter so it would be dated mid 1930's unless its been put together with parts. The pump and vent are very eary, bail is wrong, and can't tell about other stuff from your picture. Nice items you picked up
Jan
Scouterjan
Iron Man
Postby campmaster-k » Fri May 25, 2012 10:36 pm
I just had one of those moments in life that one hopes for. My son who is 18 and independent about 30 % of the time told me tonight that he is done with propane and want to take a white gas Coleman on an all night fishing trip. So we went through the drill on white gas and he says to me why didnt I do this sooner? Sometimes there is peace in the universe. Ommmm. Ommmmm.
All joking aside I knew he would come around. :thumbsup: :thumbsup: 8) 8)
-Kirk
Build thread -
campmaster-k
