A REALLLLL challenge...done!
Postby Wolffarmer » Sun Jan 30, 2011 6:03 pm
The German or Mexican Borgward?
Randy
Wolffarmer
Images: 309
Postby doug hodder » Sun Jan 30, 2011 11:51 pm
Like it would matter......Doug
Postby Mark72 » Mon Jan 31, 2011 7:57 pm
I'm not much of an import guy, But those Hansa 1500 sport coupes are cool little cars!
Mark
Mark72
Images: 127
Postby doug hodder » Sat Feb 05, 2011 2:19 pm
With as much grease as there is in this stove, you'd think it couldn't rust but that's not the case. It's apart, but the rust is so heavy that this may get a hammered finish on it. It was originally in a wrinkle, but the color is no longer available and while there are ways to wrinkle the paint, I don't think I could do it evenly so that it would look appropriate. The hammered should really hide the rust issues. Doug
Postby doug hodder » Thu Feb 17, 2011 7:15 pm
After a degreasing/ stripping it 2 times, considerable time in a blasting cabinet and a few tacks with the mig welder to repair the broken spot welds. I sanded/primed it, did some spot putty work, and got it in paint...box needs 1 more coat. I'm doing it in a hammered paint as it hides a lot of issues. Kinda tricky to get an even appearance on it out of a rattle can. There is 1 hairline crack in the cast grate.
Now if the snow would quit....and it would warm up this Sat. I can finish up on the paint and put it together. Doug
Postby starleen2 » Thu Feb 17, 2011 7:30 pm
NICE Doug :thumbsup: - that hammered finsh realy does cover a multitude of "sins" :angel:
starleen2
5th Teardrop Club
Postby Zollinger » Thu Feb 17, 2011 7:34 pm
So your saying... a hammered finish for an old hammered stove? :bowdown: I just might have to try the hammered finish paint on my next project.
Dawn
Green Lantern Corpswoman
Zollinger
Images: 64
Postby Darren » Thu Feb 17, 2011 8:16 pm
That really came out great. :thumbsup: Nice work Doug.
Darren
the camper formerly known as Victor Star
Images: 161
Postby Wolffarmer » Thu Feb 17, 2011 9:33 pm
Can I spray myself with that hammered look paint?
:lol: :lol:
Randy
Wolffarmer
Images: 309
Postby hotrod » Thu Feb 17, 2011 10:05 pm
Wolffarmer wrote:Can I spray myself with that hammered look paint?
:lol: :lol:
Randy
some of us prefer to drink our hammered look finish... lololo :oops:
Paul
hotrod
TILT
TILT
Postby Wolffarmer » Thu Feb 17, 2011 11:55 pm
:lol: :lol:
Randy
I'll drink tot hat rothod
:tipsy:
Randy
Wolffarmer
Images: 309
Postby doug hodder » Fri Feb 18, 2011 12:08 am
Slowcowboy...I don't do sand....I'm very fortunate and have access to a blast cabinet that isn't mine and Mike has it loaded with glass beads. Glass beads are much more forgiving than a sand. I did blast Woodbutchers 109 with my blaster and sand, but didn't have to do a lot, it's just a hopper and a gun. Sand will really bend and distort the metal, so it should only be used at a very low angle and at a distance. I use a really fine grained silica if using sand. Glass beads aren't the same critter, not nearly as aggressive. The cast parts can handle sand...the sheet metal can't. Never blast a spring, or a soldered joint on a stove tank, brazed like a lantern is OK...but go easy!
All the parts that are silver colored in the pic have been glass bead blasted and are in a high temp paint at this point. They look the same if just blasted....only it's a bit darker. Once blasted...get them into paint fairly quickly...moisture will be attracted to the raw iron/steel.
For paint....most any of them, rattle can or otherwise, need to be sprayed in the temps required. A catalyzed paint out of a gun will give the best gloss. It may take more than 1 coat to get a great gloss out of a rattle can. I spray a lantern font...let it cure a week, scuff it...then another coat on it, or spray clear. Gets a better gloss than just the 1 shot out of the spray can, sometimes I do this, sometimes not. I have different levels of finish depending on the item. Once done...if the garage isn't warm enough...I haul it all in the house...no one to complain here.
For a suitcase stove body...get it as straight as possible. Me...I'd not recommend bondo on one, at least in the big flat areas. The sheet metals are thin and will flex, let alone any heat cool cycles on the box...may cause a bondo to lift. I may do some rust hiding with some spot putty over primer, but no bondo, as it doesn't like to bend once cured. They all will flex over time whether you want it to or not...it'll happen.
The hammered paint I used is right out of the can, Rustoleum, hard to describe the appearance on a forum like this...go check them out at a hardware store. Some may or may not have all the colors available. It's just tougher to get the uniform finish overall with it, in my opinion.
All of this info is just based on my experiences with it all, what's worked...what hasn't....others opinions may differ.
Don't rush it....camping season is still a ways off...do it right now, or re-do it later. Doug
Postby doug hodder » Sat Mar 05, 2011 8:37 pm
I finally got a break on the weather and finished it up today. Jeremy came through with the art work for a badge on it. The original was so bad that I made a new plate and printed out a pic of the badge and laminated it. The original badge is backing up the new one on the interior. We need to work on the color a bit though.
It had been way used! 2 of the 3 burners were burned through on the rings, and the 3rd one was distorted so it got used plenty. I'm keeping my eyes open for some new rings. Pumps up fine, the cup was in great condition.
This stove is best viewed on a computer screen....I did what I could, but it's the roughest one I've ever done. The hammered paint finish provides enough texture that it hides a lot of problems. Thanks Dave for giving me the chance to do this one and get an education! Doug
Before....
After...
Postby Darren » Sat Mar 05, 2011 8:55 pm
:bowdown: That's pretty!
Darren
Images: 161
Postby Dave A » Sat Mar 05, 2011 9:39 pm
Looks to me you just got a masters degree in restoration.
I can hardly wait to see it displayed or used especially with alot of before pictures
Looks great.
Dave
Dave A
