1923 Model 1?
Re: 1923 Model 1?
Postby TRP » Mon Sep 24, 2012 8:29 pm
Hey Gang,
To make a long story, very short: He wasn't going to budge off of $150.00. I tried to talk him down a bit, but he wasn't having it. He was sure he could get more for it. I doubt he could have, but it was his stove and it was his way or no way.
I had not seen a Model 1 before and the information on them is so hard to come by, I figured they must be hard to find. If I wanted one, now is the time to buy it. So I did. :)
I didn't do any major cleaning. I wiped it down with some wd-40 to protect it a bit and just took some brass'o to the label so it would stand out.
As you can see, it's not in too bad of shape for it's age:
98200 98201 98202
98203 98204 98205
98206 98207 98208
98210 98211 98212
98215 98214 98213
I added some fuel to the pre-burner tub, pumped it up, lit the fuel in the bowl and gave it a shot. Once the fuel in the little tub started to boil, I slid the lever and moved the burners into position. The main burner lit right away, but it was pretty weak. The secondary burner wouldn't light at all. I tried fiddling with the lever with the knob (weight?) on one end, but that didn't do much. Turning the key all the way didn't have much impact.
Once I get the Benroy all done I'll turn my attention to this ole girl. See if a cleaning will do the trick.
Any suggestions? I'm all ears.
Thanks for checking back in. I'm happy to share in the excitement of my latest find.
Ted
TRP
Images: 341
Re: 1923 Model 1?
Postby Lazybones » Mon Sep 24, 2012 8:47 pm
Awesome! Glad you decided to get it. It looks good sitting on the back of your trailer.
Lee
Is it true? Is it necessary? Is it kind? Ask yourself these simple questions every time you are in doubt about any action.
Lazybones
Images: 49
Re: 1923 Model 1?
Postby doug hodder » Tue Sep 25, 2012 8:40 am
The aux burner handle only turns 90 degrees to operate. It's not an unscrew thing like on the newer Colemans.
Re: 1923 Model 1?
Postby TRP » Tue Sep 25, 2012 12:46 pm
doug hodder wrote:The aux burner handle only turns 90 degrees to operate. It's not an unscrew thing like on the newer Colemans.
This is where I expose my ignorance on this new stove (or any stove for that matter!) - Where is the auxiliary burner handle? Is that the brass lever to the rear of the main burner? The L shaped lever with what appears to be a weigh on the end? Please see the image below. Is it the lever that's up and to the rear of the burner there? (it's kind of pointing to the rear of the stove).
98211
Thanks for helping me out,
Ted
TRP
Images: 341
Re: 1923 Model 1?
Postby doug hodder » Tue Sep 25, 2012 1:16 pm
It's the little 1/8" rod with the 90 bent on the end of it. Once you get the stove into running position, that rod should poke through the outer hole in the side of the box. Doug
