It has been 2 months since I bought Coleman anything. ( not counting fuel ) Thought I would make it past June but I stopped at a garage sale this morning.
Found this
220F Jan 1971, Was burned just enough to form the mantels. Originally bought at the local Coast to Coast. No chips, no scratches, decal perfect. Box in very good opened condition.
He also had a 413E the couple had bought new when they where first married. It is one that a wire loop under the grate went around the fuel cap. I have 413# with the loop around the generator. I had to pass on the stove. Should not have bought the lantern but that lantern is sure sweet.
And talking about vintage camping equipment. Does this count?
2000 Isuzu Trooper, High mileage but every thing seems to work, except for the rear window washer and the #6 cylinder. I think injector is probably not working right. Compression is low but it should do something more than it is. When driving on gravel and I give it the boot it does like to squirrel around. Seems like it runs better at about 2000 rpm. It is a nice ride, frame has not kissed a rock, ( yet ) Looks like it been in Idaho most if not all its life. It was cheap enough. even if I do have to slip a used motor in there. I can do most the work myself with a little help from a friend. Price was right even if it does need work. 5 speed which I like specially on a higher mileage rig. Get it running right and I might go to a Scamp or similar 13 footer. But who knows?
