Just wish the other 288 and 275 would show up.
Scott
kzhorse wrote:It is just about perfect just the top and bottom mouth are a little bigger from what I can figure out about the original.
Is it common for the bottom to be steel and the top of the font be brass?
Scott
kzhorse wrote:But it is just a Coleman look-a-like the quality is not the same the fit and finish is not as good the ventalator is just painted,bad welds and the glass is not marked with any markings.
But I did fill it up and it burned for about 12 hours last night.
Scott
Milspec info (From Neil McRae)
Only the Coleman Milspecs had a model number. Coleman called the original 252 and when the quad globe was introduced in 1952 gave it the number 252A. None of the others have a number. So there is no such thing as an SMP 252A for instance.
Early production from 1944 and 1945 were made by AGM, Akron, and Coleman with Aladdin making burner sets to convert exising lanterns and possibly to supply burners for the other three.
From Neil and Warren: (anyone have a 1962 or 1970?)
1944 Akron, AGM (Albert Lee,MN), Coleman (Wichita, KS)
1945 AGM, Coleman
1951 AGM
1952-1961 Coleman
1963 Coleman, Thermos
1964-1966 Coleman
1967 Coleman, AutoFab
1968-1969 Coleman
1971-1972 Form-Tech
1973-1976 Coleman
1977 Armstrong Products (Huntington, WV)
1978 Armstrong Products
1979 Coleman, SMP (State Machine Products, Dry Ridge KY)
1980-1991 SMP
canned o minimum wrote:Hmmmm... that lamp shade looks a bit COMBUSTIBLE ! Are ya sure it'll hold up to the heat ?
