BernzOmatic lantern - stuck valve
Postby opie051699 » Fri Feb 20, 2009 8:03 am
Can anyone tell me if there is a way to clean or repair the brass valve on these old BernzOmatic lanterns...it worked fine for years, then started sticking, now the flow has stopped completely....this pic is not mine...but mine looks just like it.
opie051699
Images: 6
Postby Mark72 » Fri Feb 20, 2009 6:52 pm
A couple of questions.. Will the knob turn or is it froze? If the valve turns but no gas did you store it with the tank off? Mud daubers will plug even the tiniest hole even if they can't nest in it. And of coarse I know its silly but I must ask..Are you sure there is gas in the tank?
Mark
Mark72
Images: 127
Postby opie051699 » Wed Feb 25, 2009 7:53 am
I had two valves...one never worked the other did. The good one was stored on the gas tank, and it is full. The knobs turn, but no gas is getting out....
opie051699
Images: 6
Postby opie051699 » Tue Mar 17, 2009 7:29 am
bump.
opie051699
Images: 6
Postby Mark72 » Tue Mar 17, 2009 9:39 pm
Have you tried another tank? Maybe the valve in the top of the tank is not letting anything through..
Mark
Mark72
Images: 127
Postby rainjer » Tue Mar 17, 2009 10:18 pm
I would take it apart & clean it.
Jeremy
rainjer
King Koleman
Images: 11
