Pin Hole Leak Fixable?
Postby clarkbre » Mon Oct 05, 2009 9:18 am
I have a Coleman Sportster 502 that is a hand-me-down from my dad. The date on it is 7/74. It is in fair condition and works great; however, there is a pinhole leak in the fuel tank. The hole is located on the side of the tank right where the bottom and side meet.
My question is, is something like this fixable? If so, how would one go about fixing this tiny hole?
I think more than anything I'm just really bummed that my dad's old stove may not see another generation of use.
Brendan
Everett, WA
clarkbre
Re: Pin Hole Leak Fixable?
Postby starleen2 » Mon Oct 05, 2009 10:38 am
clarkbre wrote:I have a Coleman Sportster 502 that is a hand-me-down from my dad. The date on it is 7/74. It is in fair condition and works great; however, there is a pinhole leak in the fuel tank. The hole is located on the side of the tank right where the bottom and side meet.
If the hole is rust from the inside out - then the tank - IMO - is gone. I Had a Coleman lantern with the same problem on the fount. I did manage to solder the hole, but then fuel just found the other weak spots and actually bleed through the metal at it's thinnest point. The Tank was rusty on the inside. They do make some rust sealer that many have used to seal the tanks - I think it's POR-15. You may be able to find a replacement tank in better conditions for less hassle.
starleen2
5th Teardrop Club
Postby Ageless » Mon Oct 05, 2009 10:43 am
Interesting how hobbies overlap . . . .
they make fuel tank sealer for antique cars; you pour it it, swirl it around and pour excess off. Check with any of the Model T vendors.
Ageless
Postby Arne » Mon Oct 05, 2009 12:19 pm
A rust spot in that area is quite likely from water sitting on the inside seam...
Would be a tough fix as the hole is probably bigger on the inside than the outside.... I don't have a clue
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby clarkbre » Mon Oct 05, 2009 12:31 pm
I'm kind of clueless too on this whole thing. I really like the stove so it might be worth just finding a nice used one. I'm trying to get a nice collection of older Coleman dual fuel products.
Brendan
Everett, WA
clarkbre
Postby Rock » Mon Oct 05, 2009 3:04 pm
Leaks in a pressure vessel full of gasoline with a fire just inches away?!?! Even if you seal it you really have no way of knowing the integrity of the tank.
To preserve the sentimental value can you get a donor tank and transfer the rest of the stove over to it? Better than nothing. Call it "patina". It can be like those American cars in Havana (they say most are 5-10% original parts) or the USS Constitution (less than 5% original I think.)
Just a thought.
Eric
Rock
Images: 48
Postby TLC » Mon Oct 05, 2009 5:16 pm
clarkbre:
I too am into the 502's (I got 6 of them now) If it was me, I'd swap out the tank with a good one and put your Dad's stove back in service. They are really easy to take completely apart and rebuild. And parts are available from a number of sources. Good luck
I can drink all day.....provided I don't start till 11PM
TLC
Images: 100
Postby clarkbre » Mon Oct 05, 2009 7:50 pm
Thanks for the advice. I'm really starting to get into these Coleman Fuel powered items. I think I will look for a new tank for it. I have the user manual and the parts breakdown and everything. Where might one find a tank though? Any good Coleman websites that aren't the actual Coleman website?
Brendan
Everett, WA
clarkbre
Postby starleen2 » Mon Oct 05, 2009 7:57 pm
clarkbre wrote:Thanks for the advice. I'm really starting to get into these Coleman Fuel powered items. I think I will look for a new tank for it. I have the user manual and the parts breakdown and everything. Where might one find a tank though? Any good Coleman websites that aren't the actual Coleman website?
A good place to start
http://www.oldtownyucca.com/coleman/
starleen2
5th Teardrop Club
Postby Micro469 » Mon Oct 05, 2009 10:21 pm
Best bet???? Ebay, Craigslist...All over the country, and Kijiji..... :thumbsup:
John
Micro469
Images: 382
Postby doug hodder » Mon Oct 05, 2009 11:02 pm
POR 15 is an alternative, but given the price of the cheapest kit, probably not worth the effort and like previously mentioned,...you're doctoring a hole in a pressurized tank full of fuel, I don't believe that POR 15 is recommended for that use. I think I'd just restore it up and use it as a static display as a tribute to dad. You can pick up a "burner" for next to nothing, and if you wanted to....put the tank on your dads one, thing is, the dates which are the important part probably wouldn't match. There is lots of this stuff available, but I wouldn't compromise any ones safety on a doctored tank. Hey...people flip out on a flooded stove as it is let alone a flame from the bottom of a tank, it can get exciting real fast!....Just my opinion...Doug
