My Sears Bighat 2 mantle lantern is HERE!
Of course I spent all night inspecting it and taking it apart. I couldn't get the main valve assembly out to save my life, so I decided to leave it. Cleaned the tank several times with some leftover large bicycle bearings and some carb cleaner. Lotsa rust in the tank spout, but not so bad elsewhere inside.
Thought it was holding pressure fine, but then realized the gas cap needed a new gasket. Have one on order. Meanwhile, I put a replacement fuel cap on it to see if the rest of the cleaned up parts worked ok and it was holding pressure. IT WORKS! IT'S ALIVE! *wipes tear*
The fount has a lot of patches of missing paint, but no chips in the hat. No overt rusting on the frame. The area around the nut where the vent attaches has missing paint, but I think that's fairly normal.
I promise to post pictures this evening!
Hugs,
Ratkity
