Scored my first 200A
Postby Alan and Lianna » Mon Aug 16, 2010 1:33 am
Found this one at the flea market for $8
After a wash
I am looking forward to restoring this one, converting my stove back to liquid fuel(new generator), and being done with all the propane bottles.
Alan
Don't just dream about it!
Wake up and make it happen...
Alan and Lianna
Images: 389
Re: Scored my first 200A
Postby starleen2 » Mon Aug 16, 2010 7:37 am
Alan and Lianna wrote:I am looking forward to restoring this one, converting my stove back to liquid fuel(new generator), and being done with all the propane bottles.
Alan
You're hooked now - nice looking coleman - should be fun to light 'er up!
starleen2
5th Teardrop Club
Postby Justin & Katy » Mon Aug 16, 2010 8:40 am
That is only the second reflector I've seen like that. Be sure to hang on to it.
Justin & Katy
Images: 81
Postby High Desert » Mon Aug 16, 2010 11:52 am
Nice find! A Coleman classic for sure, may it give you years of service. Don't forget to let us see it when you're done.
Shaun
High Desert
Images: 27
Postby hotrod » Mon Aug 16, 2010 6:49 pm
welcome to the 200A club! :thumbsup:
Paul
hotrod
TILT
TILT
Postby Alan and Lianna » Mon Sep 13, 2010 8:38 pm
The frame was rusted up
So, after reading about the electrolysis for rust removal in the cast iron thread, I had to try it out. I purchased some PH+ from Walmart, added 1 tablespoon per gallon of water and connected the Battery Charger and watched as nothing happened for the first day. The next day I added more PH+ since I am on well water and thought that might be the problem, still nothing. The battery charger I am using is an automatic one that also has a 100 amp start setting. I flipped it to 100A and the frame started bubbling, then when I set it back to automatic it would continue to bubble, it needed the higher amperage to get it started. Well after 3 to 4 days this is how it came out.
Then after some sanding, priming, and several coats of paint and a trip to the oven. I reassembled the lantern.
Now I just need a label and to fire it up...
Alan and Lianna
Alan and Lianna
Images: 389
Postby hotrod » Mon Sep 13, 2010 8:48 pm
:thumbsup: :applause: :applause: :applause:
Paul
hotrod
TILT
TILT
Postby Wolffarmer » Mon Sep 13, 2010 9:09 pm
Beautyful job. :thumbsup: :thumbsup:
singing "Another one bites the dust"
Randy
Wolffarmer
Images: 309
Postby Alan and Lianna » Thu Oct 28, 2010 4:38 am
Well, after the purdy paint job, I tried firing up the lantern and found that the check valve was stuck and the packing nut was leaking. I freed up the check valve by filling the tank with lacquer thinner and soaking over night. It actually only took about an hour to free up the valve, but figured letting it soak overnight wouldn't hurt. I was going to order the packing but found the instructions for replacing said to tighten until it stops leaking, so I tightened the nut and eventually it stopped leaking. Since the Lacquer thinner totally jacked up the paint job, I disassembled, repainted and installed a new generator and leather. Now that the lantern looks nice and works as it should I installed a label and its ready to go...
Alan
Alan and Lianna
Images: 389
Postby CliffinGA » Thu Oct 28, 2010 7:13 am
Alan I like the label!!! :lol: :lol:
Cliff
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby Zollinger » Thu Oct 28, 2010 5:14 pm
:thumbsup: :thumbsup: :thumbsup: I give it three thumbs up!
Dawn
Green Lantern Corpswoman
Zollinger
Images: 64
Postby suckerpunched » Tue Dec 14, 2010 11:33 pm
Beautiful work,,,,,,Will have to try the electricolis thingy on mine or at least a new paint job,,,,,,well done :) :)
TC
If you see my harley on a trailer,,,,call the police cause it's being stolen...
suckerpunched
Images: 22
Postby canned o minimum » Tue Dec 21, 2010 9:20 pm
God help this poor man !? He's got the Coleman sickness fo sho !
Great resto job..and I love the decal !!!
canned o minimum
