Not pictured:
SMP Mil-spec
"Sears" 275
Coolers
Water Jugs
Lantern Cases
Stoves
Jeremy
doitright wrote:Hey Rainjer Woul love to see photos of your Sears stoves? I found a sears light green stove with folding legs would like to ID it but still can not upload photos.
on the bottom it has model # 476.72244 The top and bottom at front and back is rounded and not square like a coleman. Would you know if Sears had others make there stoves?
doitright
Here is my Sears stove before I restored it.
This one is similar to the Coleman 413. They also a 425 size one.
Jeremy
High Desert wrote:Doitright,
Does your's look something like this one? This is an earlier model, a 476 74960 dated 5/66. This pic is as I found it. Good running stove. Almost identical size as a 425 but also configured a little different. I like the raised grill on it. They used the yellow trim on them for a while and then went to black like Jeremy's stove. Then switched to the green around '70 or so from what I've seen. This was made by Coleman for Sears.
Ratkity wrote:
Christmas Tree, Sears Big Hat, 2007 limited edition
Hugs,
Ratkity
hotrod wrote:wolfarmers missing nut is on top of the parts lantern at the left...
