Tanks and rust
Tanks and rust
Postby doitright » Sat Nov 13, 2010 12:11 am
I got the BB method down and it works great. But what can I do to keep the rust from coming back? I know that once there it will come back very easy. I have seen some costly gas tank coatings or is there a less costly method to keep the rust from coming back.
doitright
doitright
REAR DOOR CAMPER
1959 REAR DOOR SCOTTY
doitright
Images: 38
Postby High Desert » Sat Nov 13, 2010 12:32 am
POR15 makes a tank sealer that works really well by all reports but it costs a bit. The upside is one small can will do a bunch of lanterns. I got some from a friend but haven't had a chance to use it yet myself.
I'll see if i can find a link for it just for the record.
EDIT; here's the link. Not too bad for the small can, just takes a couple of teaspoons worth to do a lantern fount
http://www.por15.com/US-STANDARD-TANK-SEALER/productinfo/TSG/
Shaun
High Desert
Images: 27
Postby doug hodder » Sat Nov 13, 2010 9:32 am
I think I'd be concerned about the POR 15 getting into the air tube from the pump and sealing it, unless you just poured it in to coat the bottom. POR 15 requires you to pour it in a tank, then rotate the tank to coat all sides. It will fill holes, so the tube on the pump runs the risk of getting plugged.
I've only done automotive fuel tanks however. Doug
Postby Rock » Sat Nov 13, 2010 9:40 am
One technique used is to use an aquarium air pump to pump air into the pump tube (with the check valve removed is better) to keep a continous flow of air going into the tank. Should cure the sealant faster and will prevent the tube from getting blocked.
Eric
Rock
Images: 48
por 15
Postby doitright » Sat Nov 13, 2010 11:21 am
I have seen this product but never used it. I think it may become the #2 step of the rebuild. BB then por 15.
doitright
doitright
REAR DOOR CAMPER
doitright
Images: 38
Postby High Desert » Sat Nov 13, 2010 12:23 pm
Doug and Rock make good points. The people I know that use it mainly just use enough to coat the bottom and the lower edge & seam. Also make sure to have the F/A tube out. Rock's suggestion of an aquarian pump is a good one. It does speed up the cure time.
Shaun
High Desert
Images: 27
Postby Arne » Sat Nov 13, 2010 1:22 pm
The bottom seam is the most important.... that is where the water would settle.
Also, take the pump out.... then do it.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby doug hodder » Sat Nov 13, 2010 7:10 pm
Rock wrote:One technique used is to use an aquarium air pump to pump air into the pump tube (with the check valve removed is better) to keep a continous flow of air going into the tank. Should cure the sealant faster and will prevent the tube from getting blocked.
Eric
Good tip! Doug
