Salvaging Flint From an Emply BIC Lighter
Postby PresTx82 » Sun Feb 27, 2011 11:22 pm
I posted this over at the Coleman Site but I thought I'd share it here as well.
Recently I have acquired a number of lanterns with the Coleman Spark Igniter attached to them. I removed them a placed them aside as I began my lantern disassembly and clean ups. Most of the igniters had no flint in them, or they were greasy/dirty and wouldn’t light. I took them apart and cleaned the various small parts as we do the other lantern copper parts in Simple Green to remove the grease and a good wash in vinegar to remove the rust and corrosion.
I had asked earlier on the forum if the replacement flint that is normally used in lighters was the same and of course the answer came back that it was and very inexpensive at the local drug store or Wal-Mart.
I found an interesting article on the web where you can rescue the flint from a BIC lighter that had run out of fuel. I know buying a replacement flint is only a couple of dollars but I wanted to try my luck at taking something else apart. I think most of us have this problem.
Find a BIC lighter that is empty.
Remove the striker by prying it off with a small screwdriver being careful not to launch the striker and flint across the room because it’s being held in by a spring.
Once you get the pieces apart you should have the above pieces. Here’s the flint.
Take a pair of dyke pliers and cut the flint into two pieces. You will need a shorter piece to put in the igniter system and now have enough flint for two igniters. You may want to place the long flint in a small plastic bag before you cut in half or it’ll launch across the room. I did notice that the spring in the BIC is the same size diameter as in the igniter and I'm thinking that you could cut that down to replace any broken or damaged springs in your igniter. I haven't tried this yet but I will.
Now replace the new cut down flint into the cleaned igniter and reattach it to your lantern.
Now wasn't that easier and more fun than driving out and buying one?
Mark
El Paso, Texas
PresTx82
Postby teardrop_focus » Mon Feb 28, 2011 2:13 am
Not bad! if you know where to find people who use those then discard them.
I've gone through a spark ignitor phase... once the flint's spring is heated more than three or four times, even in it's retraced postiion, it seems to lose tension and then the rig won't generate spark. At that point I remove the spring, stretch it, and replace it... then it lasts two or three times; you get the point.
Paul calls these things "fingerburners". Hahaha.... I've removed most of mine save for the one or two that still work... but as soon as they stop working then they're being removed for good. I now take the time to remove the vent and globe and start my lanterns that way, w/ a match.
I'm looking to obtain a butane mini-torch or a good-quality fireplace lighter w/ the long nose for lighting lanterns. I like to use a butane torch to preheat my Mil Spec's generator... then the lantern ignites perfectly; Mils Specs are known to be "finicky" lanterns, and are, if the gen isn't warmed up. The lack of an internal, remote-operated cleaning needle for the jet doesn't help matters.
teardrop_focus
Images: 127
Postby PresTx82 » Mon Feb 28, 2011 6:07 pm
I guess I'm going thru that phase now. They're piling up. I just wanted to clean them up and use them. I haven't had the springs go out yet. I'd rather take off the vent and use an old fashion match, but for now I'll tinker with the igniter.
Mark
El Paso, Texas
PresTx82
