Repair cage on 228F
Repair cage on 228F
Postby kzhorse » Sat Nov 05, 2011 6:02 pm
Not sure what it is called but one of the 4 vertical strips that are tack welded has come loose.What would be the best/easy way to fix it? Or just let it go?
Scott
kzhorse
Postby Dave A » Sat Nov 05, 2011 6:25 pm
The most obvious but not cheapest is to find a shop that has the ability to re weld it.
Being " thrifty " myself I drilled one part with a clearanse hole and the other part with a hole sized to accept the tap #o-80 machine screw.
So far this has worked for me.
Dave
Dave A
Postby Woodbutcher » Sat Nov 05, 2011 7:53 pm
I would look for a donor lamp. I may even have one. That is the Big Hat model. If you are interested PM me. I bought a beat lamp for 2 bucks that was painted green. I can check out the cage condition Monday. You can have the cage if you pay the postage.
Woodbutcher
Postby kzhorse » Sun Nov 06, 2011 1:21 pm
Woodbutcher wrote:I would look for a donor lamp. I may even have one. That is the Big Hat model. If you are interested PM me. I bought a beat lamp for 2 bucks that was painted green. I can check out the cage condition Monday. You can have the cage if you pay the postage.
Thanks for the offer,Let me try to get a good tack on it and see how it works first. Has anybody ever media blasted and electroplated or just use high temp. paint?
Scott
kzhorse
Postby doug hodder » Sun Nov 06, 2011 7:23 pm
I bead blast them and use the Rustoleum VHT silver paint. You can also do the citric acid treatment on it for the rust, unless it's got real rot.
The Rustoleum gives a nice looking light gray...not a shiny appearance, I think the real shiny stuff doesn't hold up to spilled fuel as well and any handling will make it look funky real fast.
Plating is going to run you a bunch of $$ unless you plan on doing it yourself with some of the "shade tree" methods. Doug
Postby kzhorse » Sun Nov 06, 2011 7:37 pm
Plating aint that big of deal we have a small 220 volt brush/sock style electroplating machine at work as long as they have the chemicals its all good.
Scott
kzhorse
Postby campmaster-k » Mon Nov 07, 2011 9:36 am
I have been using the same paint Doug wrote about. It seems to hold up very well. :thumbsup:
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
