Mark72 wrote:That's not the same thing Sharon. Use that procedure on a lamp and there will be fire!
Mark
campmasterk wrote:Sharon - You should start out with a model 288 lantern. It is a newer model that is very easy to light, has a somewhat small stature, and will adjust from dim to very bright. The 288 is a gateway lantern, the gateway to being a Coleman Keeper!
S. Heisley wrote:campmasterk wrote:Sharon - You should start out with a model 288 lantern. It is a newer model that is very easy to light, has a somewhat small stature, and will adjust from dim to very bright. The 288 is a gateway lantern, the gateway to being a Coleman Keeper!
I've got plenty of friends. I'll give them the pleasure of carrying and messing with that thing! After all, if I start on Colemans, you'll have more competition at buying those guys!
