by eamarquardt » Tue Jan 24, 2012 11:23 pm
I, for one, would not like to participate in "the rustiest font" contest.
If I come across a really rusty font, I'll clean it with bb's, acid, abrasive media, or whatever and then fill it with water and put a pressure gauge where the generator goes and see what pressure is obtained by pumping by hand.
Then, I'd put a schrader valve in a Tee, with the gauge on the second leg and the third leg of the Tee into the font and pump it up to about 3 or 4 times the normal working pressure. If it explodes the water won't go far or burn.
Only after it passed this test, would I consider using it with fuel.
A test rig would cost less than ten dollars. My emergency room copay is about $40 not to mention the other issues associated with an emergency room visit.
Gus
