It real dirty but its not bent and the tank is healthy inside.
Its a cool wild find I have never seen one in person before, $10.
doug hodder wrote:I'd clean it up carefully with a lot of elbow grease and a nylon or softer brush, don't do a wire one!!!!...go with the grain of the aluminum stamping to get the grooves cleaned out. It's not an easy clean up, but can be an easy screw up. If you decide that you don't want to do the work on it....lemme know....I'd buy that one off you! Doug
