Ok, you folks have worn me down and I'm thinking of picking up some white gas stuff. There was a 4F stove at the same junk dealer where I found the "Avon" lantern. It looked to be in pretty good shape with moderate rust on the wire legs, and not much pitting on the sheet metal. I couldn't find a date, but I assume it's later in the run because it has a brass tank and the sheet metal is green. What little I've found says the earliest were black and black.
I think I'll go back for a second look, any idea what I should offer?
-Greg
