Finally got to the bootfair!
Postby campmaster-k » Sat Apr 14, 2012 8:49 pm
What a great day. Beautiful weather ---- and the Bootfair yea.
This is what I got . Now I keep telling you all that I am NOT a stove collector but I cant seem to stop buying them. One of these is for me and one is for Doug if he wants it.
I am in the cast iron club now! I have enough stuff to be considered to be a Keeper but I really felt I was not worthy till today.
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Re: Finally got to the bootfair!
Postby campmaster-k » Sat Apr 14, 2012 8:54 pm
The next stove is very cool.
-Kirk
Build thread -
campmaster-k
Postby logman7777 » Sat Apr 14, 2012 10:04 pm
Cool Finds!
Coleman Keepers 200A Gang
High Wide and Handsome Probationary Member
Happy Camping!! -Andy
logman7777
Postby doug hodder » Sat Apr 14, 2012 11:13 pm
Those both are great finds Kirk! I was on the phone with Jeremy tonight and we decided that the Coleman was most likely a 6B. The clues are the wing nut on the fuel tank, lack of the towel bar/ lid rest, side valve for the aux burner and the Everdur decal on the lid as well as the fold over type flat bar legs. The burners in that one are called "band-a-blue".
The Pre-Way is very similar to the Handi Chef that I have, both are manufactured by Pre-Way. My Handi Chef was marketed through Sears and has the bent wire grate, not cast. It is a preheater type stove. How you lit that one up was to, pressure up the tank, lift the little wire tab sticking out from the side of the manifold and hold it while you cracked the valve and dribbled some fuel into the cup, shut down the valve. The wire tab diverts the fuel from the manifold into the pre-heat cup. Light up the cup and let it burn off. Once it boils the fuel and burns off, it has preheated the gennie, then crack the valve and it should light at the burner. I usually use a small amount of denatured alcohol when lighting up that type of stove as sometimes it's tough to regulate the amount of fuel with the valve on a stove of that age.
That's a really nice stove! As with any stoves of that vintage...take your time and don't get carried away with tearing into it. Go slowly.....It also has a bayonet type aux burner control.
What ever stove you have found for me is greatly appreciated and yes...I would love to have one. I will compensate you well and will give any stove a great home with a lot of it's buddies. I don't have either. Thanks for thinking of me. Doug
Postby Wolffarmer » Sun Apr 15, 2012 3:19 pm
Wow, nice haul there. Bet you where glad you had your CRV there to carry all that iron for you.
Randy
Wolffarmer
Images: 309
Postby Woodbutcher » Sun Apr 15, 2012 7:43 pm
Nice find Kirk....by the way you ARE a stove collector. Don't fight it, just go with it.
Woodbutcher
Postby campmaster-k » Sun Apr 15, 2012 9:22 pm
Woodbutcher wrote:Nice find Kirk....by the way you ARE a stove collector. Don't fight it, just go with it.
No No I have way too much stuff. I am in thin mode. Desirable lanterns are exempt.
I am selling off stuff cheap!
-Kirk
Build thread -
campmaster-k
