Coleman 286 Lamp Problem
Postby Sandyman » Thu Aug 09, 2012 7:47 pm
I have a 286 that surges or pulses after it is been running for a short time. :x I pump up the pressure and the pulsing decreases but soon comes back. Does anyone know what the problem is and how to fix it. The lantern is about 3 years old and has not been used all that often (4 or 5 trips). Any help would be appreciated.
Sandy C :wine:
Sandyman
Re: Coleman 286 Lamp Problem
Postby Wolffarmer » Thu Aug 09, 2012 9:48 pm
While I am not familiar with the 286 plussing seems to be caused by, Too small Mantle, Fuel pick up tube spring needs streached. ( doubt that on a lantern that young but who knows. ) Or have you ckecked that the fuel cap is sealing?
Or you might have a lantern that is often referred to as a "Disco" lantern.
Might be the generator.
Randy
Wolffarmer
Images: 309
Postby High Desert » Thu Aug 09, 2012 11:48 pm
On that model I'd guess generator first. Try cycling the valve all the way open and shut several times, see if that helps (doing this works the tip cleaner up and down). 286's are a later model and usually nice and easy to use. You can also see if your fuel cap is sealing well with a little soapy water around it. If it's loosing pressure that could also cause an issue.
Shaun
High Desert
Images: 27
Postby Sandyman » Fri Aug 10, 2012 7:04 pm
Thanks for the info on things to check. I will look at them this weekend and report back. Anyone else with more info do not be shy.
Sandy C. :wine:
Sandyman
Postby Flash » Fri Aug 10, 2012 11:19 pm
I agree with what HighDesert said, sounds like you have a bad generator.
Also, Make sure that the lantern has plenty of fuel.
Flash
Captain Coleman
