NIER FEUERHAND
NIER FEUERHAND
Postby Eddielbs » Sun Sep 23, 2012 9:48 pm
This weekend I went to a garage sale an found this 1920ish antique German NIER FEUERHAND Nr 260 lantern complete with globe for 3 bucks. After cleaning out some grass and a few bug bodies it seems everything is in working order. I'm going to try to fire it off tomorrow once I get some oil.
"Some Minds are like cement, A grey matter that is thoroughly mixed up and permanently set."
Eddielbs
Images: 120
Re: NIER FEUERHAND
Postby campmaster-k » Mon Sep 24, 2012 12:07 pm
Oil lamps are cool. I do not have one. Maybe I should?
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Re: NIER FEUERHAND
Postby Eddielbs » Mon Sep 24, 2012 1:20 pm
It's werking. :) And all it needed was a cleanup and some oil. In even using the old dry wick that was in it.
Eddielbs
Images: 120
Re: NIER FEUERHAND
Postby Eddielbs » Mon Sep 24, 2012 1:24 pm
campmaster-k wrote:Oil lamps are cool. I do not have one. Maybe I should?
it's not as bright (sometimes I like that) as my Coleman's but the simplicity of it is great.
Eddielbs
Images: 120
Re: NIER FEUERHAND
Postby Dean in Ct. » Mon Sep 24, 2012 3:36 pm
If the wick is old and dry you ought to let it sit in a full reservoir of fuel for a while before lighting, or a few drops carefully drizzled from from above goes a long way toward getting the capillary action primed. I suspect you knew all that! Nice score.
Dean in Ct.
Images: 32
Re: NIER FEUERHAND
Postby GerryS » Mon Sep 24, 2012 5:37 pm
Just bought two of those a couple weeks ago. Dietz sent their mfg to China....at least fuerhand is made in Germany....
Lehmans hardware is so cool! , It's in Ohio, up near canton...Kidron I think.....in the middle of Amish country, and definitely worth thrip if your in the area...
GerryS
Re: NIER FEUERHAND
Postby logman7777 » Thu Sep 27, 2012 5:59 pm
Walmart has the knockoff Dietz's for $6 but they are slapped together. I use em around the Gazebo and when Camping filled with Tiki Bugbiter.
Coleman Keepers 200A Gang
High Wide and Handsome Probationary Member
Happy Camping!! -Andy
logman7777
