by Rock » Wed Oct 24, 2012 10:08 am
237 500 candlepower kerosene only model. What an awesome find, especially for $2. Easily worth 25 times that. The correct glass is bulged like a 200A but only larger - specific to the 500 CP models 236/7.
Be careful with the rebuild instructions as they are for gas models only I believe - there are some differences.
This is kerosene only. It has to be pre-heated with alcohol in the little copper cup inside before lighting. If you try to light it like a gas model you're likely looking at a fireball.
These things are beasts. Any run-of-the-mill Coleman like a 200A, 220, 228 is rated at basically 300 candle power.
What a great find - I just found my first one as well. Fix her up, light her up and enjoy - but running this at most campgrounds is likely to get you run out as it is crazy bright. Great for boon docking however.
Eric
