repainting stove
repainting stove
Postby droid_ca » Wed Nov 21, 2012 12:37 am
I just picked up a camper that has an oven and stove combo and I'd like to repaint it can I just paint over the enamel or should it be sanded down I have no powder coaters near me as that would be my best option so I'm going to try and repaint it..
So What is the best way???
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Re: repainting stove
Postby Shadow Catcher » Wed Nov 21, 2012 7:50 am
You need to find very high temperature paint and one thing to remember is that paint used for a barbeque for instance will not stand up to the scrubbing that happens on a stove top. As you pointed out powder coating is probably the best solution and I would be seeking some one out that can do that, despite the difficulty. I chose a stainless steel cook top for CR and do not regret it.
Postby logman7777 » Sun Nov 25, 2012 9:47 pm
Is it enamel paint or porcelain? Either way there are kits that allow you to paint or apply a durable surface. Check with Eastwood dot com or even lowes or home depot. Good Luck with the recolor!
Coleman Keepers 200A Gang
High Wide and Handsome Probationary Member
Happy Camping!! -Andy
logman7777
Postby droid_ca » Mon Nov 26, 2012 6:14 am
I believe that it is enamel on it...Thank you I'll check those places out
“Fide Canem”
droid_ca
Images: 176
