I resized the pic in photobucket so it wouldn't be so big but they take a while to get the edited pic synced up with the link. Hopefully it will correct itself soon.
doug hodder wrote:The black one should be flexible. I've found some O rings that will substitute for it. While not fuel resistant, they will work but then I don't leave the stove full of fuel all the time anyway. On the pump gasket...this pump is smaller in diameter than the Coleman pumps, but I've taken the Coleman leathers and trimmed them down a bit so that they will fit into the pump tube. Worked for me. On a lot of this stuff, you can spend forever searching for just the right gasket or just doctor up one that will work. Doug
PS..take the nut off the bottom of the pump tube...you should have a check valve in there that may need some maintenance.
doug hodder wrote:Doubtful...once it goes hard, it's gone. Check it out however...many of the older tanks used lead as the seal. A sharp object will scratch it and you can tell if it's lead or not. Sometimes they can be cork also. Doug
