"I spend years saving up and building my dream custom water-cooled gaming PC setup and what do I do with it? I watch a man go camping in a made-up plastic hut........................and I love it!"
"Not sure which is more awesome. The origami structure or Steve."
WizardOfOdds wrote:Here is a well done Zig-Zag (my nomenclature, he calls it a "double pop top"). I always liked the Zig-Zag for it's rock-stable open/close transitions with minimal effort (you only lift half the top weight at a time with no loose ends to connect), zero exposure to rain during erection, and the ability to leave it half opened in extreme wind. However, building one with rigid walls is a challenge, especially if you want the door head room to increase with opening.
If you don't need to walk on the top, it could be made a lot lighter and probably not need the gas struts. But, I see it a better match to a trailer because the pickup cab restricts access to the front end (how does he raise & lower the front, from the inside?). A disadvantage is the diagonal member restricts window placement. And things get a bit more complex if you need a vertical back (to accommodate a tall door).
WizardOfOdds wrote:A few notes on the instant pop-up folding hut in Steve Wallis video of my 5/20/2022 append.
Here is my diagram of his hut which you may find helpful.
Two beautiful things about the Wallis hut:
(1) it makes very efficient use of 4 x 8 panels, and
(2) it folds into a 4x4 square stack
But such huts with more than 3 sides put both of these properties at risk...
With regard to (1), Steve's hut only needs five 4x8 sheets and leaves you with only a single 4x4 remnant. But for configurations with more than 3 sides, the height of the roof triangles must exceed half the wall width to realize a roof peak. So for 8 ft wide side walls, the roof triangles must be more than 4 ft high. This complicates cutting the required segments from 4x8 sheets and means the folded roof peaks will protrude beyond the folded side squares unless you make the sides at least as tall as the roof triangles. I avoided both these problems in my 4 sided scale model by adding a peak vent.
Finally, there is another advantage to these configurations: you can overlap segments, which reduces the foot print but increases the peak height which strengthens the entire structure against wind and rain. Overlapping also minimizes any leaks associated with the open joint seam. For example, you can build a 4 sided unit with a shallow slope roof, but erect it as a triangular hut for poor weather or to get extra head room as a shower house. That's a rare flexibility, even for fabric tents!
RJ Howell wrote:WizardOfOdds wrote:Here is a well done Zig-Zag (my nomenclature, he calls it a "double pop top"). I always liked the Zig-Zag for it's rock-stable open/close transitions with minimal effort (you only lift half the top weight at a time with no loose ends to connect), zero exposure to rain during erection, and the ability to leave it half opened in extreme wind. However, building one with rigid walls is a challenge, especially if you want the door head room to increase with opening.
I've attempted to contact him to understand just how it operates. I can see a piano hinge between the two tops (on the side). I'm designing again, trying for hard sides and like this wedge/full lift of his!
OP827 wrote:Another retractable caravan. Not sure if it is commercially manufactured of home made. This time from Czech Republic.
What is interesting is the lower door frame design that allows function it as one piece with upper door half.
"Another retractable caravan. Not sure if it is commercially manufactured of home made. This time from Czech Republic.
What is interesting is the lower door frame design that allows function it as one piece with upper door half."
"I like it, I've been playing with the idea of one that goes up and down or in and out but decided to KISS for my first one, no moving parts."
