My Giant Teardrop build
Postby SuperTroll » Tue Jun 24, 2008 10:04 pm
Thing is, I kind of wanted to have a rail around the deck, and with these "fold outs" I'm not sure how to work that out. I could have a removeable rail.....
so why not a DROP rail...hinge it..lock it in the UP position with a pin, pull the pin and fold it down /(Out) level with the deck when you use a slideout....?
Keep thinking outside the box and all manner of ideas will become reality......
http://home-and-garden.webshots.com/alb ... Ul?start=0
SuperTroll
Postby Ivar the Red » Tue Jun 24, 2008 10:21 pm
SuperTroll wrote:Thing is, I kind of wanted to have a rail around the deck, and with these "fold outs" I'm not sure how to work that out. I could have a removeable rail.....
Yeah, I'm thinkin that...or somthing like the sides of a stake truck.
Johnny
BUILD THREAD
Ivar the Red
HOME RUN TILT
Images: 373
Postby toypusher » Wed Jun 25, 2008 7:36 am
Johnny, you could do something like this for the deck in front. This is a front view with the blue being the deck surface, the red is the extensions, etc.
Of course you could scale it so that the extensions and the height of the railings match so that when it is folded, nothing sticks out!!! :D
toypusher
Images: 324
Postby Ivar the Red » Mon Jun 30, 2008 5:33 am
Ok, I won't bore you with more pics of a plain black frame, but I do have a tip. We decided to use the Ospho for our rust conversion(thanks eddielbs) and it works just fine. But as with the others I tried, it turns black. As I'm painting the frame black it was a small problem seeing where I had already painted. So I used some gray primer first then the black paint. Small problem solved, I hope any others I encounter are as easily solved as well.
Johnny
BUILD THREAD
Ivar the Red
HOME RUN TILT
Images: 373
Postby Ivar the Red » Sat Jul 12, 2008 11:17 pm
More baby steps tonight. Frame(on the bottom) is ready for paint, and reassembly. Sparks before sawdust...I'll be glad when this is over, I'm more comfortable with wood.
Help has arrived
Morsund Teardrop Works,Inc Lead Foreman.
No, the flamingos are not dead, just trick photography
I guess the work is done for tonight.
Johnny
BUILD THREAD
Ivar the Red
HOME RUN TILT
Images: 373
Postby bdosborn » Sun Jul 13, 2008 1:19 am
Ivar the Red wrote:More baby steps tonight. Frame(on the bottom) is ready for paint, and reassembly. Sparks before sawdust...I'll be glad when this is over, I'm more comfortable with wood.
<snip>
Boy are you preaching to the choir here. I can't seem to remember not to run my thumb over welds to see if my joints are flush.
:roll: :oops:
Images: 806
Postby toypusher » Sun Jul 13, 2008 6:11 am
Johnny, great to see you making some progress!! :)
toypusher
Images: 324
Postby Ivar the Red » Sun Jul 13, 2008 4:19 pm
<snip>
:roll: :oops:
Yeah that same thing works when grinding something smooth. :lol:
Johnny
BUILD THREAD
Ivar the Red
HOME RUN TILT
Images: 373
Postby toypusher » Wed Jul 16, 2008 9:21 am
Johnny, where are the pics of the painted frame???? Inquiring minds want to know!!! 8)
toypusher
Images: 324
Postby Ivar the Red » Wed Jul 16, 2008 9:57 am
toypusher wrote:Johnny, where are the pics of the painted frame???? Inquiring minds want to know!!! 8)
Had a small rain delay yesterday, and still need to touch up here and there. It's coming.
Johnny
BUILD THREAD
Ivar the Red
HOME RUN TILT
Images: 373
Postby Ivar the Red » Mon Jul 21, 2008 6:20 am
Ok, here they are...with yet another question to follow...
Now for the question. This frame already had 12 holes in each side for axle placement, if I move the axles I could only possibly use 2 of the holes on each side,clear as mud?
Any way here is the real question, can more holes be drilled into the frame without weakening it???
Johnny
BUILD THREAD
Ivar the Red
HOME RUN TILT
Images: 373
Postby Arne » Mon Jul 21, 2008 6:27 am
Don't know where the existing holes are, but holes in the vertical plane are usually ok... too big a hole in the horizontal plane will weaken the member...
If you stick with the hole size they used (assuming they were factory done, not home drilled), you should be okay.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Ivar the Red » Mon Jul 21, 2008 6:40 am
Arne wrote:Don't know where the existing holes are, but holes in the vertical plane are usually ok... too big a hole in the horizontal plane will weaken the member...
Hole location...
The holes they are in now look "factory" the others don't.
Johnny
BUILD THREAD
Ivar the Red
HOME RUN TILT
Images: 373
Postby Ivar the Red » Mon Jul 21, 2008 9:52 am
Hole location...
bump.
Johnny
BUILD THREAD
Ivar the Red
HOME RUN TILT
Images: 373
Postby SuperTroll » Mon Jul 21, 2008 11:01 am
consider welding plate over the existing holes...
SuperTroll
