What you want to do is called "flat-towing." I have friends who tow cars and jeeps behind their RVs all the time.
Check this out...
http://auto.howstuffworks.com/auto-part ... tions3.htm
CD
jss06 wrote:I would look into some way of using either surge or hydraulic over electric to activate the rear brakes on the VW. It really will help.
Don't forget you will also need to wire the taillights to the tow vehicle and possibly side marker lights as well.
jnyjetta wrote:OH, the plan is to run it without the steering rack. While the free spindles scare me a ton, I'm told by very reliable sources this will work just fine.
jss06 wrote:You will need a tie rod or some other connection between the spindles or the tires will not track and will splay out.
