I started out building a trailer for my bicycle when I was 13... It worked well. I even hauled lumber with it. I later on built some for scooters and motorcycles... Both one and two wheelers.
I like the single wheel trailers the best (except for heavy loads). I think they track better and I have never experienced one trying to gyrate or sway. I built one as far back as 1962 and first pulled it behind a Cushman Eagle with no problems. I've pulled them behind a number of larger bikes since then. Most of the ones I built had no suspension. I did build one from an old motorcycle frame that did. We just used 2 go kart front spindles to make the hitches... It is still a very good and simple way to do it. The spindles are welded together back to back in a cross. The spindle on the trailer stays bolted. The front one uses the spindle bolt to lock it into the vertical tube on the rig we built to fit the bike. We also sometimes used junkyard U-joints on some for the swivels. On most of the later ones we used 2" exhaust pipe tubing for the frame tube because it was light yet strong enough and easy & cheap to get custom bent. I built a few with Coleman coolers for the box... hey, we used them to haul beer to the beach mostly anyway.
These little Uni-Go's are really cool... But they have a pretty hot price!
Uni-Go hitch... (a U-joint type)
Uni-Go...
friend ~ Brick
SIDE NOTE: I just bought a new hydraulic tube bender... so I will prolly build another one or two sometime soon.
