Slide out?
Slide out?
Postby H@nk » Sat Oct 06, 2007 4:59 pm
Hello all,
Here a question from the Netherlands.
Somewhere on this forum i saw a few pics from a teardrop with a slidingout.
Can anybody tell me how that has done?
Will the weight rase extreme? I can tow with this Chrysler Voyager over 3000lbs, but the problem here is when i built a thing towing by the car it's more heavy than 1500lbs it has to go to the gouvernment. I don't like that.
I hate taxes and other things to pay. I was thinking building a TTT, but a little bigger that tiny. I realy need a big bed because my growth is 6' 11".
My DW likes a (porta potty) toilet and my 2 DD's like sleeping in their tent.
So, what do you think about this?
Henk
Old bread isn't hard, no bread, that's hard.
H@nk
Images: 81
Postby Miriam C. » Sat Oct 06, 2007 8:35 pm
Image to the playground Henk. Here is a link that should take you to a wonderful slide out.
http://tnttt.com/viewto ... t=slideout
You might also check out Steve Fredericks build.
http://tnttt.com/viewtopic.php?t=12886
It is bigger but I don't know the weight. My TD is quite large but not for someone as tall as yourself. You will need something much longer! :thumbsup: ;)
You can make any TD longer and taller if you can get a trailer to put it on. I look forward to seeing some great pictures from your country!
Postby angib » Sun Oct 07, 2007 10:42 am
Welcome, Henk.
How about this small caravan built in the Netherlands - at least you can read the Dutch language on his site easily!
Image Image Image
The Simplicity is only 250kg (550lb): http://www.tante.nl/zzhugo/index.html
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby H@nk » Mon Oct 08, 2007 6:21 pm
Hello Andrew,
I can read it very easy, because it is my language, but I can also read your language, it is only a little bit diferent as english.
Just try to and if there is something you dont understand,ASK henk.
Henk
H@nk
Images: 81
