Patches - Popup to Roundtop Standy Conversion
I've been working on building a roundtop standy camper on an old popup camper frame. Since ya'll like pictures here are some of Patches. I call it that cause it's built of bits and pieces of whatever I can scrounge.
Hitch and one side. Other side is a mirror image. Windows are from an old camper shell. Spare tire and mount are from the donor popup.
View of the back/door end. Lights are from the popup. Door is from an old camper that has severe water damage. Back "porch" is a piece of 2x10 screwed into the popup bumper.
Inside showing couch. Started life as a futon frame. Removed the ends and bolted it to the walls of the camper. Just a little shimming needed to make it fit perfectly. Plastic boxes underneath will work fine for storage till I get/make time to build something better.
And a picture with the foam removed. The plywood is the same as I used for the rest of the camper. Scrap from a box plant. All I had to do was go get it.
Couch in down or bed position.
Starting to skin the inside. The plywood I am using as the inside skin is packaging vinyl siding is shipped in. I LIKE free stuff! There are some dints and dings but I can live with them till I get something better.
After putting the first piece up I decided to cheat and jack the ceiling panel into position. The jack is an old mechanical house moving jack and was a LOT easier to use than trying to hold the paneling in place with my head and back while screwing it into place.
Second row of the top done. Now for the hard stuff in the front corners. Hope to finish that part tomorrow.
That's all for now. Will try to post more as I get it done. If you are interested in seeing more of the build pix, there are more posted on my blog.
Later,
dave
Later,
dave
