Triming your tear
Triming your tear
Postby Jeeper92 » Tue Dec 04, 2007 9:36 pm
I was wondering what options are available when triming the corners of your tear? I know steves puffin put some sort of black stuff on his corners
Just wondering what everyone else is doing
Jeeper92
Postby Kens » Wed Dec 05, 2007 11:35 am
I too would like to know. Maybe something in plastic or rubber? I have a problem with small cracks showing up every once and awhile on my wall and roof seam. :thinking:
Good day every day!
Kens
Images: 26
Im finishing
Postby Jeeper92 » Wed Dec 05, 2007 8:02 pm
Im finishing another one this weekend with auminum strips from the box store but they bend and break too easy. I break one everytime i wheel it out of my garage. I may have to keep this one, my son got hold of a red spray can and painted the side today. So i am hoping that reular exterior paint will cover it up. i gotta email steve about his puffing he put some sort of rubber stuff on his
Jeeper92
Postby toypusher » Wed Dec 05, 2007 8:03 pm
If you are using aluminum, are you annealing it first before bending??
Check this for info on annealing: http://tnttt.com/search ... de=results
toypusher
Images: 324
no
Postby Jeeper92 » Wed Dec 05, 2007 8:19 pm
im kinda justl ooking for something that looks good nad is sturdy that i can jsut slap on there
Jeeper92
Re: no
Postby madjack » Thu Dec 06, 2007 12:04 am
Jeeper92 wrote:im kinda justl ooking for something that looks good nad is sturdy that i can jsut slap on there
...goto your local RV place and get some RV corner molding...it should already be "dead" soft and ready to bend...if you use al angle from the box stores, you will have to anneal it first........
Postby packerz4 » Thu Dec 06, 2007 1:04 am
you could use duct tape, and cover it with the shiny aluminum foil tape...that would stick super good, just be sure not to snag or tear it.
good luck!
tk
:roll:
~ Go Packers! ~
www.2bagalot.com
packerz4
Images: 53
Postby Miriam C. » Thu Dec 06, 2007 9:20 am
I used wood trim and covered it with marine epoxy. Used thickened epoxy to fill any cracks or gaps too. On top where the trim covers a seam I built a dam on all edges of epoxy to keep water from forcing it's way in.
Kens, you might look into Architectural Epoxy too. It goes on like putty and remains lightly flexible. It is intended to fill wood that may shift some.
Good luck.
