Page 1 of 2
The Simple square
Posted:
Sun Jul 11, 2004 11:30 am
by angib
Here is the Simple, the most basic 4x8ft square to go on a Harbor Freight utility trailer. It has two alternative profiles depending on whether you want just a bit of 'teardrop-i-ness' or none at all:
Here are the plans:
The Simple. I've tried to eliminate as much cost/material as possible - the hatch props are pieces of wood, but work semi-automatically, and the windows are just polycarb sheet with no frames.
Andrew
Posted:
Sun Jul 11, 2004 1:15 pm
by RC
Good work Andrew. I like your version a lot better than mine. You definitely have an artists eye.
I am not sure whether I like the squared off back end or the slop backed one better. Thanks for your efforts!
Posted:
Sun Jul 11, 2004 4:21 pm
by angib
OK, you now have three alternatives to chose from:
The
Rimple (Rounded Simple, geddit?) is the third one and is on the bottom of the
Simple page.
I understand that many people think a flat-panel body will be easier to build than a curved one, but I suspect it isn't so - the joints at the angles of a 'square' are relatively complex. So actually I think the Rimple would be the easiest to build.
Andrew
Posted:
Sun Jul 11, 2004 4:47 pm
by mikeschn
I suppose the e-simple is next?
P.S. e? elliptical of course...
Posted:
Sun Jul 11, 2004 7:44 pm
by RC
I am thinking that the hardest part to build is the galley lid. It seems like the rounded one would be the hardest to get right. What are your thoughts on that?
Man, you just keep cranking out the hits!!!
Posted:
Sun Jul 11, 2004 8:56 pm
by RC
Another question...will 1/4 inch plywood bend to the 24 inch radius without breaking? Also, how does one get the seams to seal on the top where the 2 pieces of plywood meet?
Posted:
Sun Jul 11, 2004 9:17 pm
by RC
Hey Andrew, how about the Srimple? Simple and rounded together!
Posted:
Mon Jul 12, 2004 7:09 am
by angib
RC wrote:Another question...will 1/4 inch plywood bend to the 24 inch radius without breaking? Also, how does one get the seams to seal on the top where the 2 pieces of plywood meet?
Nope, which is why the Rimple uses 1/8" thickness ply for the front, top and hatch.
The seam in the front/top is about 12" from one end, so it falls in a flat section. A butt strap joint* can be used, or make the seam fall on a rib and make that rib double-width.
I've put a cross-section of a butt strap joint
here.
Andrew
Posted:
Mon Jul 12, 2004 7:10 am
by angib
here.
Andrew
Posted:
Mon Jul 12, 2004 9:18 am
by RC
<<Nope, which is why the Rimple uses 1/8" thickness ply for the front, top and hatch. >>
Darn, I should have caught that when I was loking over your plans. Thanks...
I guess I should use a double width rib, as I would imagine that a butt strap joint would be hard to do on 1/8 inch material. Probably doable on 1/4 inch material though.
Posted:
Mon Jul 12, 2004 12:49 pm
by RC
Also Andrew, what version of TurboCad are you using? The version I am running is 4.1, and it is unable to open your files. It shows an appropriate preview, but has a header error that prevents it from opening up.
RIMPLE BENROY
Posted:
Mon Jul 12, 2004 2:23 pm
by Dee Bee
The Rimple looks alot like a very simple Benroy. What is the difference?
DEE
Re: RIMPLE BENROY
Posted:
Mon Jul 12, 2004 3:18 pm
by angib
Dee Bee wrote:The Rimple looks alot like a very simple Benroy. What is the difference?
Dee,
Not much. The rear radius is reduced so that the hatch hinge is in the flat roof, not on the start of the curve. So there's no problem in making an angled joint between the bulkhead and the roof. And the door is simpler.
Andrew
Posted:
Tue Aug 10, 2004 10:33 pm
by RC
Andrew,
When I do finally build my enclosure, should I cut the flooring down on the sides so when the side pieces are attached, it makes the thing 4 feet wide, thereby letting the top sit down better for weather-tightness. Like in the picure here, looking from the front (or rear).
Posted:
Wed Aug 11, 2004 5:31 am
by angib
Yes, absolutely. I had drawn this with some framing under the floor so that the floor and side can be joined securely:
Andrew
