Outdoorsman Sleeping-Pod Idea
Postby lilgription » Thu Sep 12, 2013 7:47 pm
This is a little sleeping pod as I call it that im going to start building next week. This will be used this fall and winter for my hunting trips. It will slide onto my existing utility trailer. Its a 4 wide design 7' in length. Rear full width door to aid in loading supplies ,etc. Just the basics here , nothing fancy. I will be building a 5x9 size similar to this next year on its own trailer. Let me know what you guys think. Thanks and God Bless112266112267
lilgription
Images: 27
Re: Outdoorsman Sleeping-Pod Idea
Postby CliffinGA » Thu Sep 12, 2013 9:09 pm
Nice but add one side door that way it helps twice, one if you load everything from back you will still have access towards the front 3 feet and second at night when you have to go pee easier to go out from the side door than scrunching back down and opening the big door! Just my thought anyway!
Cliff :thumbsup:
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby lilgription » Thu Sep 12, 2013 9:34 pm
Ive pondered the side door. But I may just hinge the rear door on its side. With the utility trailer already having side rails I don't think the door on the side would be easy to get in and out of. that would make the side door under 30" tall and well over 24" off the ground maybe more like 36" off the ground
lilgription
Images: 27
Postby pmowers » Thu Sep 12, 2013 9:46 pm
Have to agree with Cliff. Not to mention, if it is winter, you are going to let any heat in the trailer out. Spent a lot of time backpacking in one-man tents that you had to crawl into and out of as they were one step above a bivy bag.
Growing old is mandatory, growing up is optional.
Build log:http://www.tnttt.com/viewtopic.php?f=42&t=51193
pmowers
Images: 43
Postby schaney » Sat Sep 21, 2013 10:20 am
Hmmm, I like the door at the rear. With the raised sides not sure you could make a door work.
Scott
Camping the "Compact Way"
schaney
Images: 262
Postby kudzu » Sat Sep 21, 2013 10:29 am
While a side door may not work well for routine entrance/exit, it could certainly come in quite handy for quick access to the front area.
kudzu
Images: 16
Postby lilgription » Sun Sep 22, 2013 11:40 pm
I have started a build thread over in the build thread area. LOL.. I am still doing a rear door but it is not the whole back end. I came across a 42" tall X 31" wide RV cargo door. I also acquired a larger window that has approx. a 24" X 24" fire escape option ( just in case ). Check it out over in the build section
lilgription
Images: 27
Users browsing this forum: Google [Bot] and 3 guests
