The Allwood - it's all wood
OK, it's about time we had some heresy around here. I've said before that I think it's possible to build an all-wood teardrop without any metal. Well, I admit making the suspension and coupler in wood would be difficult.
The Allwood
So I've been drawing up what I think would work. This is effectively a boat on land and needs similar skills to build it. Doing it without epoxy might be possible, but I doubt it. This is not some simple, cheap alternative to buying a steel frame - it would be both harder and more expensive.
The fundamental thing is the body design has to change to eliminate the thin, flexible tongue or A-frame that cannot be made easily in wood. Instead the whole body extends down to the coupler. The Wanderbug in the Vintage Plans section has some diagonal braces from the body to the tongue that do a similar job:
A similar monocoque/unibody design could be used for an all-composite teardrop.
I don't claim this is a proven design - it's just a starting point. I don't mind if you don't believe it's wise, or even possible, but if so I hope you won't mind if I don't believe you. Anyone who has experienced the forces that go through a large sailboat when it gybes won't think a few bumps are a serious problem, and there are almost no sailboats built with a metal chassis inside them!
The Allwood
