All-Season Off-Road Tiny Trailer
In an effort to put off a larger project, I've started a tiny trailer! The purpose is two-fold. First, the project will keep me busy and happy while the company I work for runs out of money. Second, the finished trailer, assuming it doesn't crumble into a pile of pieces, will be a cozy place within which me and my girlfriend can escape the weather during some of our many outings. I'll tow it behind my '98 Wrangler Sahara across terrible terrain in bad weather. (In good weather, we'll be usually backpacking in the wilderness around Seattle.)
I've already benefitted greatly from the expertise on this board, so I have decided to give back - with comedic entertainment in the form of me trying to stick a trailer together.
Basic criteria:
1. Lots of ground clearance and durable undercarriage
2. Warm, comfortable bed
3. Lots of windows
4. Not too heavy
5. Sink, faucet, stove, and USB plugins
6. Lots of insulation
7. Street legal. Probably.
8. Pass-through galley to prepare food in nasty weather
The what-the-heck list (in case I don't run out of money):
1. Furnace
2. 12v cooler
3. AC inverter
4. Solar charging
5. Extra lights
6. Can carry my WR250R
7. Water pressure
8. Crude leveling jacks
9. No leaks (one can dream)
I have:
1. A long shopping list
2. A tilting flatbed trailer - 4.5' x 9' - with a title, plate, and current registration
3. Plenty of tools
4. Some crappy drawings and a crappy wiring diagram
5. Three wheels (don't loan wheels to friends) that match the Jeep wheels enough to share a spare
6. Some recent success with solar power
I have already done a lot of shopping - $800 worth. The sum on the shopping list is $3200, but overruns are already the name of the game. The way I look at it, this is cheaper than the other project I'd be doing, both in terms of money and garage space. I've also darn-near finished my house remodel, so there's that void.
I also now have:
1. An obvious penchant for making lists
2. 30 square feet of diamond plate
3. Way too much square tube steel (I've just learned) - maybe I'll subtract that from the total budget
4. Wheel spacer/adapters to accept the Jeep wheels. They're good quality, and the wheel offset is such that I don't think there will be any additional stress on the torsion suspension.
5. Wrong-size lugnuts (d'oh) - I already had plenty in that size too - and I just ordered the correct set
6. A 100ah deep-cycle battery on the way
7. A small inverter on the way
8. A bunch of wire, all sized correctly for the loads expected
9. A stove that a friend gave me and which I thought I'd never use
So this should be fun! It's already been fun doing research and planning. Last weekend, I used the Jeep's winch to lift the trailer onto its side and then wire-wheeled the minor surface rust off the frame. Then I treated it with rust reformer and put on a layer of undercarriage coating.
Next is expanding out the trailer about eight inches to the sides and up. I made some good templates for that today and cut all of the square tube steel that I'll weld onto the frame for that. The next step is to weld those on. When I was cutting the old side bars off the trailer, I learned that two of them had been filled with water for who knows how long. I know a lot of vehicle frames have drain holes, so I think I'll connect the new side pieces to the trailer frame with small holes and then put some small drain holes in the bottom of the frame.
That's it for now. Thanks for tuning in.
Basic criteria:
3. Lots of windows
4. Not too heavy
1. Furnace
2. 12v cooler
3. AC inverter
4. Solar charging
5. Extra lights
7. Water pressure
I have:
3. Plenty of tools
I also now have:
