Once again, a half-car pseudo-teardrop
Postby groys02 » Wed Jan 26, 2022 8:21 pm
Greetings!
'Been quite a while since I've been active on here. Last time around, I'd built a sort-of teardrop out of the back half of a 4-door neon, with a scratch-built front end. Used that off-n-on for several years, and then got out of Neons... and sold the NeonLyte to another central-Iowa camper.
55353
Since then, I've revisited the English Fords that I've been fond of for about 50 yrs now. I bought a '58 Anglia (2-dr sedan), which is nearly done now... I guess we'd call it a "resto-mod"; semi-restored, but in a modified form. (83 Corolla drive-train)
While it was under reconstruction, I bought a '59 Prefect (4-dr sedan), figuring to rob a few parts from it for the Anglia... but mostly to turn 2/3 of it into a sort-of teardrop, as I'd done with the Neon.
And I'm currently tearing down the Prefect, getting ready for the slicing-and-dicing.
Now, if only I can figure out the picture-hosting thing..............
(looks like I first put them in my album, then link them to here... so I'll have to upload some more pics to album. stay tuned.)
"You wouldn't worry so much about what others think of you if you realized how seldom they do."
— Eleanor Roosevelt
groys02
Images: 140
Re: Once again, a half-car pseudo-teardrop
Postby groys02 » Wed Jan 26, 2022 8:57 pm
Okay, a few more pics added to my album, so I'll try inserting them in the body of the thread.
Assuming I pull that off, pic one is of my '58 English Ford Anglia alongside my '59 Prefect (4-dr version). I got the parts car primarily to chop up into a small teardrop-style trailer for the Anglia to pull around. The Anglia has the whole drive-train from an '83 Corolla wagon, so it should be capable enough... out with the tiny 1180cc flathead engine, and in with a 1600cc Toyota 4AC + 5-spd. I've been driving the Anglia around the neighborhood for the last couple years... no hot-rod, but way peppier than the stock format was.
168179
For the last week I've been tearing down the parts car. Engine/trans out now... hood, fenders, all 4 doors removed... etc.
168180
With an old version of CorelDraw, I've tried to mock up what the car/camper will look like... 12" shorter, taken out of front door and roof... new floor will eliminate driveshaft tunnel... rear torsion-bar half-axles will allow trunk floor to drop much lower, so plenty of room for feet below the galley. This layout should provide something over 7' of room front-to-back, and interior of car is approx 4' wide.
When I did the Neon version of this scheme previously, I used all the stock floor & rear suspension, and it still only weighed approx 750#... so I figure the Prefect version will be lighter, somewhat, than that.
168181
— Eleanor Roosevelt
groys02
Images: 140
Postby groys02 » Thu Feb 03, 2022 12:54 pm
Well... now the old car shell has been gutted, and this morning I cut off the front section.
I'll add some bracing, both side-to-side and diagonally, to stiffen the shell before cutting the floor out. I'm going with torsion bar half-axles, so that I can keep the floor flat, front to rear.
I'll also remove 12" of the car body's length, which will give me a bit over 7' from face of dash to inside of back-panel, and will have the centerline of rear wheels approx. 40% of the way forward from the rear. (I picked up both of those suggestions on this forum.)
168245
— Eleanor Roosevelt
groys02
Images: 140
Postby groys02 » Thu Feb 03, 2022 12:57 pm
And the casters are on the body temporarily, front & back & midway, so when I cut the 12" out of the body I can 'simply' roll the front part back to the rear part, and began welding them back together again.
And then start building the new frame & floor..........
— Eleanor Roosevelt
groys02
Images: 140
Postby groys02 » Tue Feb 08, 2022 5:10 pm
And the dismantling continues...
Over the last few days I've removed the floor in a couple big sections, after adding some EMT-tubing triangulation to preserve the shape of the shell, once minus both floor & firewall. [I don't know if that was absolutely necessary, but why risk things getting warped?]
The front half of the floor was definitely a lot easier to remove than the rear half... some pretty substantial stamped steel bracing in the area around the front of the leaf springs. [I still have a chunk of that to remove.] But, all-in-all, it went pretty smoothly.
I'll have some tidying up to do of the remaining bits of flooring, before figuring out the frame... already checked with the local steel supplier on what dimensions of rectangular tubing are 'normal', so as not to design something that relies on hard-to-get bits.
168284
Got the torsion half-axles by mail yesterday... the wheels a few days earlier. Wheels are 13" x 4.5" wide, 4x4.5" lug-spacing. Half-axles are rated for 935lbs, which should be comfortably more than the camper/trailer will weigh... and the axle assembly is very compact, with approx. 1.5" between mounting plate flange and inboard edge of rim... so the frame won't need to take much out of the interior space for the floor. And the hub assembly is bolted onto the frame part via a splined shaft, so I can dial in the ride height after the frame is built & assembled.
So far, so good.............
168285
— Eleanor Roosevelt
groys02
Images: 140
Postby groys02 » Sat Feb 12, 2022 5:20 pm
Went ahead today, and cut that 12" of length out of the car body. The proverbial point of no return.
168302
Shoved the pieces together, and they fit pretty well... a little minor trimming to do here n there, and then I'll separate the big pieces again and grind the edges to be welded clean of paint, rust, etc. Then I can get back to actually welding it all back together again.
168303
Because of the slight tapering down of the top of front door, I'll have to do some little pie-cuts to bring drip rail back into alignment. Nuisance-some work, but not nearly so bad as chopping a top, which I've gotten talked into twice before..........
168304
— Eleanor Roosevelt
groys02
Images: 140
Postby groys02 » Thu Feb 17, 2022 3:32 pm
Got the 2 halves of the trailer-to-be prepped... rejoined, with either sleeves [rocker area] or backing strips [roof cuts], and countersunk SS pop-rivets holding it all together. Even the 'jog' in the drip-rail mostly disappeared, so a little hammer & dolly work, and I can weld that up.
Still waiting on frame steel, but I'll be a few days getting this welded together..........
168322
— Eleanor Roosevelt
groys02
Images: 140
Postby groys02 » Thu Feb 24, 2022 9:26 pm
[hope I don't accidentally post twice today... but I don't see what I thought I just posted]
Got a start on welding seams back together again yesterday. Went into town today, and picked up the new steel for building frame [11ga 1x3 and 2x3 rect tubing] and front/firewall area [20ga sheet steel]. That, plus the torsion axles already gotten, and the tongue jack which came a few days ago, makes for all the basics now on hand... so time for lots of cutting/shaping/welding. More later..........
168402
— Eleanor Roosevelt
groys02
Images: 140
Postby groys02 » Wed Mar 02, 2022 8:33 pm
Another couple days, some more work done. Cleaned up the remnants of flooring from the inner rocker panels today... then mocked up the location of the 2x3 frame rail at the rear of the camper-to-be... and clamped the wheel-plus-half-axle to the 2x3. Looks like it'll work out okay, with the wheel/tire about where it needs to be, and the mounting flange for the half-axle where it needs to be, when the frame rail is where I want it to be.
[hope that made sense] Big relief, for the sketched-out plans falling into place, so far.......
168436
168437
168438
— Eleanor Roosevelt
groys02
Images: 140
Postby groys02 » Fri Mar 04, 2022 4:55 pm
One side of frame pieces tacked together, and carefully flipped over....
168455
— Eleanor Roosevelt
groys02
Images: 140
Postby groys02 » Mon Mar 07, 2022 1:48 pm
Had to clear out the shop yesterday to repair the wife's car.
This morning got back to work on the teardrop... winched the frame forward, into position, from underneath the body shell.
Tight fit, but worked out reasonably well. A little tweaking with its position, and I can start welding the it in place.......
168484
168485
168486
— Eleanor Roosevelt
groys02
Images: 140
Postby groys02 » Tue Mar 08, 2022 8:15 pm
Semi-productive day, for a geezer.
Initial welding done, body-shell-to-frame... wheels & torsion half-axles installed... on her feet at last.
Time to finish up welding, on body splicing from earlier, and more thoroughly between car inner rockers and new frame.
If I can wait that long, then I'll return to fabricating the front panel with spare recess.
168518
168519
— Eleanor Roosevelt
groys02
Images: 140
Postby groys02 » Sat Mar 19, 2022 1:50 pm
Tongue jack added... now fitting new front panel halves, and spare recess.
'Some beading here & there for stiffening purposes. Back of the spare recess will be added later, as I think I'll need all the access I can get for welding recess to side panels. Made myself a lot more work by forming 2 halves of a radius with bead roller, but I really didn't want just a right angle there... so it goes.
168566
168567
168568
— Eleanor Roosevelt
groys02
Images: 140
Postby Shadow Catcher » Sat Mar 19, 2022 2:53 pm
Encountered the BedBug at CRA last year, it is however four down. Lots of neat ideas i.e. where the gas tank was is a water tank. AC where the engine was.
Postby groys02 » Sat Mar 19, 2022 5:50 pm
I've seen 2 articles about the BedBug... they had fun putting that together.
I drove old air-cooled beetles for quite a few years, so it has nostalgia appeal for me as well.
— Eleanor Roosevelt
groys02
Images: 140
