Unnamed 12' Travel Trailer
Postby Bengrey » Sat May 07, 2016 6:31 pm
Hello all!
I'm happy to finally be able to share with you images and my build progress so far.
This trailer began it's life in 1989 as a Jayco pop up. When I bought it, it had been essentially dismantled with only the bottom structure remaining, I believe the previous owner was using it as a cargo hauler of sorts. After tearing off all the remaining bits I was left with this awesome bed to build on
141400
The frame dimensions of it are 12' by 7' and it comes in at a whopping 640 pounds. This was a bit larger than I had originally planned to build on, but I'm now extremely happy with the options its given me.
If you notice the steel tubing on my trailer, that's the material I decided on to build my frame. I chose 1x1 steel tubing due to it's light weight properties and structural abilities. By no means am I an expert welder, but the enticement of getting to weld my entire structure was... pretty intense, and this was probably my favorite part of the build so far.
3 solid days of cutting and welding yielded my camper's frame
141399
141402
141403
I then spent the next few days completely buffing, sanding, and painting my entire trailer in rustoleum. Which was pretty nice as a trailer base as old as mine had accumulated quite a fair amount of rust
141404
I'm further along in the build, but would really love to hear everyone's opinion/comments/expertise on how this stage of my build went
Cheers!
Bengrey
Images: 10
Re: Unnamed 12' Travel Trailer
Postby KCStudly » Sun May 08, 2016 2:27 pm
Fabrication looks fine from what I can see at a distance.
So it looks like it will be a rear entry, do you have floor plan figured out?
I wonder what it weighs now. :thinking: Your little marshmallow tires will have a load limit that you will have to stay under, unless you upgrade and allow room for larger tires and wheels.
Postby Bengrey » Sun May 08, 2016 7:40 pm
Rear entry is correct sir :) I've got the floor plan figured out somewhere... just cant find the doodling that I had done so I can share. Entry and head will be located at the rear with a kitchen(ette) along the side over the wheel well. Since it's 7' wide and I'm only 5'7" plenty of room to stretch out at the front. The weight at this point I have figured to be around 850 lbs. I can only safely guesstimate that because....
141406141407
After spending an incredible amount of time sheeting the entire exterior and installing trim. I completed my first road test yesterday! :D Straight to the weigh station lol
Came in nice and happy at 1000 pounds
Bengrey
Images: 10
Postby tearjerker » Mon May 23, 2016 6:50 pm
any news on your build or pictures, im keeping an eye on this build. Cant wait! :applause:
tearjerker
