I am working outside in a shelter logic unheated shed here in Massachusetts, so building time is growing short.
I started with a 2x3 frame for the deck. I went just wide enough to clear the fenders. I added eight 2x4 pieces to pin into the stake bed brackets so I could secure and then remove the camper from the trailer bed.
The framing was built with 1x1-1/2 pine that I ripped from 2x3s. I left the wall studs 4 feet high until I decided what the roof line would be. I used construction adhesive anywhere two pieces of wood came together and I used exterior sheetrock style screws for all the construction.
I used 1/2 inch plywood for the floor.
I have more done than this. I will add to this thread once I get some more of my picture straightened out.
Thanks for checking it out.
Ringwood
