Now the fun starts
Re: Now the fun starts
Postby twisted lines » Tue Nov 09, 2021 11:24 am
:BE Good eye
Trailer is looking good.
Racking up; And Rapin foam
twisted lines
Postby MickinOz » Tue Nov 09, 2021 5:38 pm
swoody126 wrote:make sure that tongue jack is mounted far enuff back so you can open the tailgate of your pick up without them making violent love w/ each other
no need to ask why i share this ;-)
sw
:lol:
I won't ask.
The jack does clear the tail gate, but that pretty much is a function of the really high bed on my truck.
Given that I will sell this trailer, I should probably move it back as far as it can go whilst still folding up properly.
I have to check all the bolt tensions anyway, so I can do it then.
We have been using a torque wrench for this build, but we were racing the rain to get this done, get the trailer back under cover and everything put away, so it's just nipped up by hand at this stage.
MickinOz
Postby MickinOz » Tue Nov 09, 2021 5:44 pm
twisted lines wrote::BE Good eye
Thanks.
Did some research, there are various websites that make all sorts of recommendationss.
Some good rules of thumb out there -
e.g.
use half the width of your vehicle plus a few inches, so that if you jackknife it the trailer body doesn't hit the TV.
don't go more than about 5 feet unless you add bracing for the flexing.
the longer the tongue, the easier to revers but the more leverage it applies to where it attaches to the trailer.
All in all, 1200mm - 1400mm, 4 to 4 and half feet, a is pretty common recommendation.
I'd like to say I planned it like that, but the truth is that is as long as I could get it and still cut out the bent bit.
MickinOz
Postby MickinOz » Thu Nov 11, 2021 9:15 am
It has now been raining for more than 24 hours and showing no signs of stopping.
My timber is under the carport, and I covered it once I realised that the rain was blowing in, but still some of it is wet.
High probability of rain forecast for every day until next Tuesday.
This is Australia - the Sunburnt Country, I live in the driest state on the driest continent outside Antarctica.
MickinOz
Postby MickinOz » Tue Nov 16, 2021 6:10 am
Today I put one door on its corresponding wall. Used this to work out the T-handle position.
Figured t out drilled an 11mm hole for the square rod to go through, fitted the handle.
Tried it out.
Beautiful.
Took it apart.
Drilled the other door.
Sanded.
Sealed with mix.
I'm biased, of course, but I do think the black door hardware looks OK on the clear finished hardwood.
MickinOz
Postby celadon » Tue Nov 16, 2021 12:17 pm
MickinOz wrote:I'm biased, of course, but I do think the black door hardware looks OK on the clear finished hardwood.
It's lovely!
celadon
Images: 15
Postby pchast » Tue Nov 16, 2021 10:56 pm
Nice contrast.
pchast
Images: 97
Postby MickinOz » Thu Nov 18, 2021 11:34 pm
Stalled.
Raining.
Average annual rainfall here since 2010 is 10.5 inches.
We've now had 2 inches in a week.
2 inches in a week is nothing to most people, I'm sure.
But when the drainage is pretty much built to accommodate the 10.5 inches p.a..............
MickinOz
Postby MickinOz » Tue Nov 23, 2021 8:30 am
My windows arrived today.
I wanted small ones to fit in the doors. Not easy to find and hundreds of dollars each.
So I got these.
$112 for a pair. Of course they are now $95 a pair.
10 inch portholes.
The missus says they are cool.
I will mount them so the glass opens inward, as they have a drain in them that will the face out.
They are meant for about a 30mm wall thickness.
2 choices - trim 'em down to suit my 12mm door, or machine a collar.
I'll ponder that a while.
MickinOz
Postby swoody126 » Tue Nov 23, 2021 8:54 am
those are COOL !
once you have located and drilled your fastener holes AND dry fitted remove them and tape/hold a piece of fabric mosquito netting/screen over the opening and carefully replace the port in the hole for fying/crawing critter protection
if using some form of water seal use the tape kind so when you need to replace the screen the ports won't be glued in place
LINK PLEASE
sw
swoody126
Postby MickinOz » Tue Nov 23, 2021 3:33 pm
Yeah mate, the plan is to do exactly that - once she's set up, lay some insect screen under the outside trim ring and screw it back down.
One thing I have discovered since I've been using Ol' #1 regularly - I cannot leave the door open for even seconds without insects zooming into the cabin. And that's in winter time! Summer will be fun.
The only complaint I have is that the drain channel is opposite the hinge, so to put the drain channel down the bottom, the hinge will have to be up the top. I'd rather it swung sideways rather than up, but I guess I can figure out a retaining mechanism.
I got 'em off amazon. There are lots of ads. Mine came from Yaemarine. They cost $57 Australian each, delivered.
You will be able to buy a pair for $49 US
https://www.amazon.com/Amarine-Made-Por ... OME_MIRROR
https://www.amazon.com.au/Amarine-Made- ... 77&sr=8-33
It's going to be a while before I do anything.
From January to October, we got 7 inches of rain.
Now we've had 3 1/4 inches of rain so far in November and its raining steadily as I type.
I work mostly outside, so I have to wait for dry days.
Winter June to August here, was a massive disappointment.
They farmers are trying to harvest something, but they ain't smiling, this rain is far too late.
The wheat is mostly grading as "feed wheat". Good thing there's so little of it that prices are actually up,
Who'd a thought you could get $400 a ton for shriveled and cracked "screenings"
MickinOz
Postby swoody126 » Tue Nov 23, 2021 4:58 pm
sw
swoody126
Postby MickinOz » Sun Nov 28, 2021 3:56 am
Rain has gone away for about 4 days according to the Met Office.
I haven't been totally in hibernation.
Got the portholes set up, ready to screw in once the doors are mounted.
Made a saw track. Nice straight cuts.
Inspiration came from here.
https://www.youtube.com/watch?v=H0BZLbW1lvQ
Porthole in door.JPG (45.73 KiB) Viewed 596 times
saw track.JPG (54.48 KiB) Viewed 596 times
MickinOz
Postby swoody126 » Sun Nov 28, 2021 9:31 am
MickinOz, thatsa GREAT LINK
just so simple it had plumb evaded me :thumbsup:
sw
swoody126
Postby MickinOz » Sun Nov 28, 2021 4:28 pm
HaHa. Plumb. Good one. :thumbsup:
Yeah I always wanted one of those fancy pants aluminium saw tracks, but when I found them for sale, they were model/brand specific, mostly for plunge saws, and quite spendy.
I was looking on Youtube for videos on how they actually work when I came across a multitude of DIY vids.
This guy's attracted me because aluminium extrusion options are not super diverse up here in the sticks, and aren't cheap.
At the same time I was looking at the videos, a bloke advertised some melamine coated 16mm MDF shelving on Facebook for $7 a piece. Delivered.
I will rework this a bit. I don't think I need those sight holes, for example. I have only done two cuts, but I found it was just as easy to work out how much to subtract from the desired measurement and just measure to the edge of the track.
Also, my stop blocks, the plywood bits at the end, could stand to be about one row of screws narrower. It's just a tiny bit fiddly getting a 1220mm/48 inch cut done.
OK for a metric sheet (1200mm)
Some glue sandpaper on the underside to give it grip, then cut without clamping it down. Dunno about that.
See the skinning knife on the table? Ran that down the side of the guide to score the plywood I was cutting. Practically eliminated splintering. Really only splinters at the sight holes anyway, presumably that is why he fits plexiglas inserts in a later video..
Planning to make one for the jigsaw, too.
MickinOz
Users browsing this forum: No registered users and 23 guests
