The Dutch build
Re: The Dutch build
Postby Marcogs » Thu May 12, 2022 2:11 pm
Tom&Shelly wrote:
Marcogs wrote:I know myself and decided to buy new ones. :cry:
The design adjusted and the new ones are already cut. :applause:
Mistakes are made, but some costs more than others.
Too bad, but you will no doubt find other good uses for the material from the old walls, so the monetary cost isn't quite as bad as the cost of material for the two new walls.
We've been there. Keep plugging! :thumbsup:
Thanks Tom, you're right. The new walls are already under construction. :thumbsup:
Marcogs
Re: The Dutch build
Postby Marcogs » Thu May 12, 2022 2:17 pm
pchast wrote:I have some trouble visualizing things and changes. I learned to always
draw full size sketches.
:oops:
Doing my foamy I used a sharpie marker to sketch the curve and the
hoped for internal cabinets on it. I stepped back and set it up on the
trailer for a couple of days to study. Then I cut things...
:thinking:
I should have taken better pictures of that point.
I still changed the final result to something else....
:D
This was the problem, the first time it was like the yelow line and the distance to the countertop was 9inch. Thats way to much.
Marcogs
Re: The Dutch build
Postby Marcogs » Mon May 16, 2022 3:25 am
Progress :)
This weekend almost finished the first wall.
Tomorrow the cable for the outdoor lighting and the inner sheet of plywood.
Marcogs
Re: The Dutch build
Postby TallGuy7 » Mon May 16, 2022 2:09 pm
Wow, that looks good! Progress indeed.
What kind of glue did you use to glue the polystyrene to the aluminium?
I am asking because I am also considering to glue the Dibond directly to the skeleton and polystyrene. Looking at other builds it looks to be common practice to add an extra layer of thin plywood, so the wall is made up out of 4 layers: aluminium, thin plywood, insulation (incl. skeleton), thin plywood. I simply do not see the benefit of this method. Imho it just adds weight. What are your considerations to this aspect of the build?
TallGuy7
Images: 26
Re: The Dutch build
Postby Marcogs » Tue May 17, 2022 3:38 am
TallGuy7 wrote:Wow, that looks good! Progress indeed.
What kind of glue did you use to glue the polystyrene to the aluminum?
I am asking because I am also considering to glue the Dibond directly to the skeleton and polystyrene. Looking at other builds it looks to be common practice to add an extra layer of thin plywood, so the wall is made up out of 4 layers: aluminum, thin plywood, insulation (incl. skeleton), thin plywood. I simply do not see the benefit of this method. Imho it just adds weight. What are your considerations to this aspect of the build?
Hi,
The glue/kit i initially wanted to use was not strong enough. I came in contact with kitcentrum.nl and i finally ended up by Zwaluw Hybrifix 302 kit. Its an solvent free glue, so if you want you can you can use it also for the Styrofoam.
I personally wil not glue the foam. It just clamps between the dibond and the inner wall/plywood sheet.
I'll go with your theory that the extra layer plywood is not necessary, but we will use dibond and that is more stif than a single layer of aluminum. Think that is the reason.
Marco
Marcogs
The Dutch build
Postby TallGuy7 » Tue May 17, 2022 10:10 am
Thanks for the tip! I used Zwaluw PU construction fix to glue the polystyrene to the inside wall (ply).
To glue the dibond to the wall I am considering Dekapur 2k polyurethane glue. This glue is used in repairs of caravan walls and it glues the wood and polystyrene and requires little clamping and looks perfect for the job.
Downside is that is is very, very expensive.
I will look into the 302…
Verzonden vanaf mijn iPhone met Tapatalk
TallGuy7
Images: 26
Re: The Dutch build
Postby Marcogs » Wed May 18, 2022 2:02 am
TallGuy7 wrote:Thanks for the tip! I used Zwaluw PU construction fix to glue the polystyrene to the inside wall (ply).
I can tell you this, the 302 is brutal. I almost teared off the topcoat of the dibond.
Marco
Marcogs
Re: The Dutch build
Postby Marcogs » Thu May 19, 2022 5:12 am
Yesterday evening.
Hot as hell, but what you gonna do :roll: :roll:
Gluing the innerwall.
I don't have a big press, so needed to be creative :thumbsup:
Marcogs
Re: The Dutch build
Postby Marcogs » Fri May 20, 2022 1:44 am
Succes :applause:
It turned-out to be great (well in my opinion)
The door frame fitted very wel.
it looks the part. This weekend I'll start with the left side.
Marcogs
Re: The Dutch build
Postby TallGuy7 » Fri May 20, 2022 2:41 am
Looks great!
The second wall should be easier in my experience. Nice shape by the way.
TallGuy7
Images: 26
Re: The Dutch build
Postby Marcogs » Fri May 20, 2022 6:02 am
TallGuy7 wrote:Looks great!
I hope so 8)
Starting this weekend.
Marcogs
Re: The Dutch build
Postby Marcogs » Mon May 30, 2022 1:52 am
How is it possible that when i want to upload a picture from 250Kb, i'll see a pop-up that the file is to big??
Marcogs
Re: The Dutch build
Postby TallGuy7 » Mon May 30, 2022 2:20 am
Marcogs wrote:How is it possible that when i want to upload a picture from 250Kb, i'll see a pop-up that the file is to big??
Install Tapatalk on your phone and post from within Tapatalk. Posting pictures on this forum is difficult due to size/resolution limitations.
TallGuy7
Images: 26
Re: The Dutch build
Postby Marcogs » Wed Jun 01, 2022 1:04 am
Second wall finished :applause:
This weekend I'll place the first (right side) wall, and the inside sheets of plywood for kitchen.
Marcogs
Re: The Dutch build
Postby Marcogs » Sun Jun 05, 2022 6:35 am
The weather is bad, but progress is made
Marcogs
