Capebuild wrote:
How did I know my wife was lightly snoring if I was soundly asleep? I just know.
Capebuild wrote:Yesterday I received my Partner Stove. Fits nicely in its space.... at least I first thought until I pulled it out on the sliding tray and tried opening the lid. I didn't account for the extra 1/2 inch or so required when the lids opens as it swings out over the back side of the stove's housing. Winds up contacting the galley wall. May have mount it on another set of sliders so when it's pulled out you then pull toward you a 1/2 inch or so... or something. Have to ponder this a bit.
Otherwise, a really beautiful piece of equipment. Well made, nicely constructed and substantial.
Can't wait to try it out.
friz wrote:You might find that you want to cook on a separate table and leave your galley space for prep. That's what I found. Also, if there is a mishap with the stove, it is away from your camper.
Sent from my SM-S906U using Tapatalk
halfdome, Danny wrote:John, the placement of the stove for me determines the layout of the galley.
You might consider placing a barrel bolt to hold it in place while cooking.
I have a receiving hole drilled in the side wall for the bolt in the open and closed position.
Danny
western traveler wrote:
When I was initially laying things out using Tony’s book as a guide I bet I slid my stove into the space a dozen times to make sure it would fit. I really like this stove! Yep, but I never once opened the lid while doing it. I will figure out a way to temporarily fasten it to the slide while traveling then move it into position when using it. Maybe Velcro or just order a Partner stove. Perhaps with the amount of back orders they have I will be able to slip it into the budget by then.
